Results 1 to 11 of 11
Thread: VS won't turn over - need diagnosis
    VS ii
    Apr 2009
    Exclamation VS won't turn over - need diagnosis
    Hey guys,
    I'm sure it is a common problem, but not sure yet...
    I have a V6 VSii Comm.
    Car not starting at all, has full charge, fuel pump is engaging but when I go to crank it there is just a single click/clunk from the engine and there's nothing.
    I hadn't driven it for a couple of weeks and it was flat when I went to drive it, so I jumped it (I earthed it, not straight to the battery) and it started fine and was good the morning after.
    Drove it to work and back, parked it in the driveway, went back out a couple of hours later to move it and it wouldn't start.
    Obviously an electrical problem, not sure about the starter because there is absolutely no movement.
    I did an error check and it came up nothing. (12)
    Any ideas?
    Would appreciate the help, I'm pretty handy at fixing anything, but I'm hopeless and diagnosis, and you guys ALWAYS find the problem for me to fix, time and time again.
    Thanks in advance, the VS would have been thrown out years ago if it wasn't for this forum. Love it.
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    click clunk??? sounds like rooted battery (cca to low) or starter! if jump starting dont work anymore then pull the starter out and test it...or just replace it. i no the process of elimination is not the best way to diag but atleast you no u now have a new starter/battery and it wont fail u for a while to come.
    VS ii
    Apr 2009
    The battery is almost brand new, there is plenty of charge.
    Could be the starter, but I thought that would crank a bit even if it's nearly dead.
    ShawtyNate's Avatar
    ShawtyNate is offline Kicker
    '94 Holden VR Acclaim
    Jun 2011
    Moree NSW
    tap the starter with a hammer then try. or try shaking the battery and jiggle the wiring, sometimes mine just goes clunk, i have to jiggle the battery along with the wiring
    vs commodore ute
    Jan 2010
    nsw
    this happended on my mates vs he had the same problems as you it was his starter that was rooted
    94 vr commodore
    Nov 2010
    sydeny
    I've had the same problem with my vr later found out it was the alternator
    VS ii
    Apr 2009
    I would think it would still start if it was the alternator if it still had full charge?
    vs commodore
    Oct 2009
    Tamworth NSW
    A faulty alternator wont actually stop the car from starting,as long as the battery is fully charged,it will start.Once the car starts though,with no alternator charging the battery, it will only run for half an hour or so before the battery will be drained.Years ago on with cars that had points and mechanical fuel pumps etc,you could drive around all day with no alternator,just on a fully changed battery alone.These days with EFI and electric fuel pumps etc,about half an hour is it..
    VS ii
    Apr 2009
    Quote Originally Posted by Brett_jjj View Post
    Yeah, I remember you could start a car with a borrowed battery and take the battery out and the car would keep running if you didn't have jumpers.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Cobra Clutch View Post
    Thats only when the alternator is working.
    VS ii
    Apr 2009
    Got it going.
    I think it was just the earth lead terminal a bit loose......
  1. VD Diagnosis
    By BlackVXGTS in forum Jokes/Humour
    Last Post: 30-03-2011, 04:59 PM
  2. VS SII Diagnosis
    By -=ApheX=- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2008, 10:20 AM
  3. diagnosis
    By darkangel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2008, 11:40 AM
  4. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  5. Self Diagnosis
    By timboss04 in forum V6 Development And Modification
    Last Post: 07-10-2005, 02:27 AM
