Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Hangman
Thread: vs lsd ?
    vs series II v6 ute
    Jun 2011
    brisbane north
    Default vs lsd ?
    hey guys i have a vs ute with a borg warner t5 in it i was wonder if an auto lsd will work properly with a manual box need to know as much info as possible recently the diff has gone and i found a replacement just need to know if it will work
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    I don't know for sure but I assume they should be exactly the same, give any local transmission/differential shop a quick call and I'm sure they can tell you for certain.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Don't see why the diffs would be different. But don't quote me, Holden like making shit hard...
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    vs series II v6 ute
    Jun 2011
    brisbane north
    vz wagon
    Aug 2006
    Wild west of Melb
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    Sedan and ute diffs are different but as long as the auto diff is from a ute it will bolt in.
    The ratios will most likely be different so your speedo will be out and your revs at 100 kmh will be different also if the ratios are different
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    Nov 2006
    Country Vic
    I should re quote myself the INTERNALS are the same just the diff HOUSING that is different if it is non IRS.
    Most manual diffs would have the 3.08 ratio.
    Regards
    Mathew
Tags for this Thread
