Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Brett_jjj
Thread: heating up in traffic??
    vsute15 is offline vs ute in the build
    VS ute
    Jun 2011
    newcastle
    Unhappy heating up in traffic??
    Ok have a little dilemma my vs ute is heating up at the lights the temperature guage goes more than half way this isnt just on hot days the coldest of nights aswell. Now when i take off after driving for 5 mins it goes back to normal. Ive checked the relays and fuses but couldnt find any blown. It hasnt got any coolant in it from what i can see. And i cant hear the thermo kicking in either So ive bought a new thermostat and new radiator coolant today and ill flush the radiator tomorrow but after that could it be the radiator or thermo or something else? Thanks for any help!
    Vs ute goes like shit off a slippery shovel.
    Some people say less talk more action. I SAY MOAR TORQUE LESS TRACTION!!!
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    does the fan come on when it gets hot if so i wouldnt worry to much as long as it doesn't get right up in the red spot it might just want a good flash not just lettin the coolant out and toping up it could just be the thermostat or radiator cap update us after you have done this
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Just give the cooling system a flush,replace the thermostat the one in it might not be opening up and then bleed it,check it the next day and add more coolant to it if needed.What condition is the radiator in? Most of them shit themselves after 2-3yrs,check that all the hoses are air tight and is the waterpump working properly check that as well and always use a coolant just using water=corrosion
    vr berlina
    Aug 2008
    I'd also renew the pressure cap while you're at it. I also found with my vr at one stage that the electrical connection for the thermo fans just to one side of the radiator was making good contact and stopping the fans from starting.
    VS ute
    Jun 2011
    newcastle
    Alright ill try everything tomorrow cheers guys ill update you's.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Nevermind.. car is V6.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VT Executive S2
    Mar 2011
    gold coast
    Get a new radiator fan fuse. The same thing happened to me and that fixed it. Cause old one was blown
    VS ute
    Jun 2011
    newcastle
    I flushed the radiator and put new coolant in didnt get round to doing the thermostat as i had to lower the rear more :P and do a service lol but ive got some ford twin thermos to go on. And ill do the thermostat also see if that sorts it!
    VS Equipe
    Jan 2011
    Adelaide, SA
    My temperature gauge goes up and my fans seem to kick in only when I am stopped at the lights, once I start driving again the gauge drops down and fans stop.
    Its always done that
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    VS ute
    Jun 2011
    newcastle
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by vsute15 View Post
    Fitting a new thermostat and fixing the overheating problem would be more important then worrying about how low the rear end sits.pfff.
    VS ute
    Jun 2011
    newcastle
    Yeah i no but i live in apartments and went to a mates place who has a shed to do everything but left the thermostat at home ( pretty forgetful leave tools every where ) but ill be doing it next.
    VS ute
    Jun 2011
    newcastle
    Yeah but it goes up pretty high. My old ss never done this!
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    Yeah,Id get it in there now,it only takes a few minutes to replace a thermostat.The same as it only takes a few minutes for a faulty thermostat to cause overheating and cook the engine.
  16. #16
    VS ute
    Jun 2011
    newcastle
    V6 champ. Yeah ill get it in today
  17. #17
    VP Exec
    Jun 2005
    Before you even think of modifying things with the Ford thermos (why?) it would be better to sort the thing out so you know where you are starting from.
    GMH does some pretty comprehensive testing of vehicle cooling systems and it's unlikely that it will need to be modified, just repaired if it has a problem at all.
    ref:
    someguy360
    Yep, the gauges move quite a lot. On V6, from ~1/4 to 1/2 is only a temp. span of around 10C, with ~1/2 ~104C i.e. normally the highest temp.. The gauges do vary a bit between cars and I think that there was an update of sender or gauge at some point and that alters the gauge reading for a particular temp. in VS too.
    If the car is new to you, maybe it's normal. It may be worth paying a workshop to perform a quick scan to check the temp. reading off the sensor for the PCM. That may be cheaper (if not as much fun) as replacing parts or performing work randomly.
    If you don't want to do that, ~$15 for a digital multimeter (Ohmeter) and a web search for the specs. - temp. vs resistance - on the sensor will get you to the same place. The part number for the sensor is moulded into the base of the connector.
    If the car is known to you and this is a new problem then, of course, you can start diagnosis with checking for coolant leaks, bleeding, thermostats etc. but I think that you may be trying to fix a problem that doesn't exist.
  18. #18
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by Cheap6 View Post
    Temperature sender unit - The temperature sender unit used in VS V6's was carried over from VR's, but the location was changed to a hotter part of the engine. This may cause higher temperature readings on the gauge before the thermo fan cuts in. In mid 1997, the sender unit was revised to suit the new engine position and engine temperatures, which show a lower reading on the gauge before thermo fan activation.
  19. #19
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    As cheap6 said you won't need au thermo's, your standard fan is good enough on the v6's
  20. #20
    VT Calais
    Jul 2011
    warnervale
    hey mate i had the same problem with my vr... i replaced the water pump cause it was leaking and i replaced the radiator cause there was a great big dirty crack in the right hand side (the side which you dont pour the coolant into) and it fixed it.. so yeh lol
  1. sv6 heating up in traffic
    By finchie in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-11-2010, 01:53 PM
  2. Heres one for you on traffic law
    By acex1138 in forum The Pub
    Last Post: 13-03-2010, 08:16 PM
  3. No traffic lights who gives way
    By LisnM8 in forum The Pub
    Last Post: 13-02-2010, 11:41 AM
  4. Fed up with traffic rant
    By adamc11 in forum The Pub
    Last Post: 14-01-2009, 06:59 PM
  5. vn overheating in traffic
    By orreal511 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 06:13 PM
