Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By Reaper
Thread: Replaced Diff.... PROBLEMS!
    VS SIII Ute 5.0L- Cammed, Stall, Headwork
    Nov 2008
    Sydenham, Melbourne
    Default Replaced Diff.... PROBLEMS!
    hey guys having some problems at the moment. About 5 weeks ago i replaced my lsd in my ute with a welded diff (lsd needed to be shimmed) changed the diffs over and all was fine. Yesterday the weld on the diff im guessing snapped because when i go round corners or when im parking it doesnt skip anymore and when giving it a bit of gas its like its slipping out of gear (just revs off its head but doesnt go anywhere). So yesterday i changed the diffs back over put everything back together go to take off and doesn't drive anywhere and when you put the car back in park from drive it makes and awful crunching sound. Is there because the gears arnt lining up properly in the crown gear or the axles havent been hit in far enough?
    Help would be greatly appreciated.
    Cheers Rhys
    vn calais 5.0
    Jun 2011
    victoria
    might be a auto prob then if you have probs with the drive? Why welded the diff and not spool it? I know spooling can get you a nice sticker tho
    vs commodore
    Oct 2009
    Tamworth NSW
    Does the tailshaft still turn when its put into gear?If it is turning,the problem is in the diff.Probably a broken axle shaft..
    Nov 2008
    Sydenham, Melbourne
    I don't think it would be a broken axle because everything wass fine when I took it out. Im thinking its just something that hasn't been put in properly. The car was still driving before I pulled it all apart again
    vn calais 5.0
    Jun 2011
    victoria
    might have to pull it apart and have a look or drain the oil out to see if there is metal in it..
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Broken weld, broken axle, broken auto - could be lots of things. Need to put the car on axle stands and properly diagnose the problem. Since you "fixed" your diff by welding it in the first place I don't hold much hope that will ever happen though.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vs commodore
    Oct 2009
    Tamworth NSW
    A diff centre needs to be set up properly anyway.The pinnion has to be set so the crownwheel tooth markings line up in the tooth centre on drive the side, and just off centre on the overdrive side.This is adjusted with shims fitted to,or removed from the pinnion.The basklash also has to be set.Ive seen diffs last only a couple of thousand k's because they werent set up properly or not at all..
    Nov 2008
    Sydenham, Melbourne
    Just started it up and put it in drive, tailshaft is spinning. When you put it back into park it makes a bad crunch sound like its not grabbing the gear or something
    vs commodore
    Oct 2009
    Tamworth NSW
    Thats because the tailshaft is still turning when you put it back into park,just like when you put it into park whilst moving along still.Its definitely something broken in the diff.
    Nov 2008
    Sydenham, Melbourne
    vs commodore
    Oct 2009
    Tamworth NSW
    Yep,or maybe just a new axle if your lucky,Id also get the new centre fitted by a diff place/mechanics as they need to be fitted properly like I mentioned above..Its a pretty hard thing to get right if your inexperienced at setting up diffs.Ive been working on cars for nearly 30 years now and I dont even bother trying to set them up myself..
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    sounds like the diff is stuffing up.. it slips.. and the transmission thinks it has to change gears cos the revs are rising.
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    I would highly doubt it has a broken axle. Surely if it had broken 1 of the axles with the welded centre in when he put the old centre back in you would have seen a broken axle.
    No good looking in the housing to see if there is any metal in there as when the weld broke from the other centre unless the housing was pulled apart and cleaned there will be pieces of metal floating around.
    Just out of curiosity when you put the welded centre in the diff did you change the pinion to suit the welded centre?? If not I would be putting money that you have smashed some teeth of the pinion wheel which will mean you will now need your lsd shimmed up as well as a set of gears.
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    Nov 2008
    Sydenham, Melbourne
    Can't b ####ed with all the headaches so I'm just buying a complete diff and putting it in, all ready to be put in just have to find one now
  15. #15
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    Did you clean out the old debris before changing over to the orig center? You may have picked up a weld or tooth which damaged to center.
  16. #16
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Get a pro to setup a diff, full stop
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  17. #17
    Nov 2008
    Sydenham, Melbourne
    changed everything over today, only took just over 2 hours. car running better than it did when i first got it
  18. #18
    Nov 2006
    Country Vic
    And the problems was?????
    Regards
    Mathew
  1. Diff problems.
    By Z2TT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-11-2011, 06:41 PM
  2. possible diff? problems
    By ilovehousemusic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2010, 10:05 AM
  3. replaced my diff with a LSD
    By TIN_MAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-07-2010, 12:13 PM
  4. VT SS Diff problems???
    By Zool in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2009, 04:47 PM
  5. vs diff problems
    By quikvskiwi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2005, 02:22 AM
