Results 1 to 5 of 5
Thread: vs digital odometer from berlina into executive
    VS commodore
    Apr 2011
    umina beach,nsw
    Default vs digital odometer from berlina into executive
    will a vs digital odometer from berlina go into a executive without much hassle? or is it a huge job?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Fit a patch loom and it will work - takes about an hour or 2.
    I've made about 70 of them now for the VR VS
    and 3 Dangerous non ABS VN's
    VS commodore
    Apr 2011
    umina beach,nsw
    what about a whole digital cluster speedo,odo,temp etc.... from a calais to executive ?
    88GreenVN's Avatar
    Jun 2006
    It's called a level 3 upgrade. You can plug a Calais clusterinto an Executive and all the gauges will work correctly - just the didgital ODO wont work until you put a patch into the Executive dash loom. This is called a 4th plug. You cant just fit a L3 dash loom as it has different A/C vs Climate. The headlights are wired different also. You cut the 4th plug and switch block wires out of a level 3 loom and graft them into your dash loom - a patch loom.
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by 88GreenVN View Post
    Do u sell some of the ones you make or know someone who does?, I am in need of one, been driving without an odometer for quite a while now
    I bought my L3 cluster as the gauges are much better looking than the L2 cluster with the crappy half tacho to make room for the giant speedo setup
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
  1. digital speedo or odometer which one to trust...
    By domtas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2010, 06:23 PM
  2. vr berlina odometer
    By rowinskii in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2010, 01:40 PM
  3. Digital odometer reset
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2009, 11:35 AM
  4. vl executive odometer cluster question
    By =TUR7LE= in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-11-2005, 08:04 PM
  5. VR Berlina Odometer reset
    By colgreen in forum Electrical Wiring / Questions
    Last Post: 30-03-2005, 12:08 PM
