Results 1 to 5 of 5
Thread: Drivers Side Door Check Strap
    V6 Ecotec White Vs Commodore Utility
    Sep 2010
    Western Melbourne
    Default Drivers Side Door Check Strap
    Gday, recently the two screws that hold the drivers side Check Strap to the door wiggled free and left the assembly hanging via the pin connected by an arm to the main body of the car.
    The Check Strap's part number is #92042531, i however, am looking for the part number/or similar, for the screws (times 2) that mount the assembly to the door i.e. behind the door card.
    Check the series 1 VT Check Strap here: http://www.iagresearch.com.au/index....=109&Itemid=40 it looks very similar
    Cheers Guys and Gals.
    HSV---'GO FAST HOLDEN'
    Sep 2010
    Western Melbourne
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Take the trim off another door - rear are easiest....screw a bolt out and buy more.....any bolt place. I'd doubt that Holden would carry them....Toowoomba Holden don't even carry a water pump for a series 2 VS!
    Sep 2010
    Western Melbourne
    Yeah guys,
    Replaced with a slightly larger bolt/nut and a tad of locktite.
    Works a treat, so lets get back to the cruising.
  1. Drivers Side Door Lock
    By nstone63 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2010, 12:54 PM
  2. VT - Dorr check strap
    By a-rod in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-06-2010, 05:12 PM
  3. check strap
    By elemenopee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 08:45 AM
  4. [WA] Fs: Vt white drivers side door with window,door skin &mirror - $60 - perth
    By Timzo in forum Parts And Other Items For Sale
    Last Post: 12-01-2009, 07:59 PM
  5. VT series 1 door "check strap"
    By cliffo78 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2007, 11:37 AM
