Results 1 to 9 of 9
Thread: air noise wen not breaking
    vs ss manual
    Jun 2011
    camira
    Default air noise wen not breaking
    I have a vs ss manual and the brakes his wen you don't use them, from the pedal, and stops wen you brake. Abs off light is on, brakes need bleeding. Anyone from yamanto or Ipswich area wanna help I'll buy you a carton and do most work if instructed. Cheers. Brand new pads and rotors. Abs module underbonnet makes ticking noise wen connected. Does it need to be bled?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    if there's air in the abs module you can try bleeding through but really need a tech1 scantool to cycle the abs while bleeding also tech1 can test each wheel hub. It could also be a abs wheel hub as they tick or pulse when active, Does it still brake normally? I have a tech1 and the Tools but am up on the otherside of toowoomba. What ABS fault code did you get?
    vs ss manual
    Jun 2011
    camira
    I get abs off. Brakes were good just no abs and now I need to bleed my new brakes and I found back left rubber brake line was split. Any help would be great
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    vs ss manual
    Jun 2011
    camira
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    vs ss manual
    Jun 2011
    camira
    Might as well set up a direct debit weekly to my mechanic. Just over the whole car
    vs ss manual
    Jun 2011
    camira
    vs commodore
    Oct 2009
    Tamworth NSW
    It sounds like a buggered brake booster. If its making a hissing noise, then its leaking vacuum.You can test the brake booster by doing the following-
    With the engine turned off,pump the brake pedal about 6 times to deplete any stored vacuum left in the booster.Then hold the brake pedal in,and whilst holding it in,start up the enigne.The brake pedal should sink in slightly as the engine is started.If it doesnt do this,then the booster is either not recieveing vauum from the engine,or the booster itself is stuffed and needs replacing.
  1. breaking down
    By dave3838 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2010, 09:09 PM
  2. Im breaking the rules of /b/
    By VryNeat in forum The Pub
    Last Post: 17-02-2009, 08:53 PM
  3. Front Brakes - Weird Noise when Breaking
    By B3NKobe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2006, 04:15 PM
  4. vl keeps breaking down please help
    By nzholden in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-04-2005, 06:55 AM
  5. breaking records
    By tr3nt in forum Site Feedback / Site Problems
    Last Post: 25-10-2004, 09:01 PM
