Results 1 to 3 of 3
Thread: How to remove VS SS V8 1995 Series 1 Power Steering Pulley without flange
    VS SS
    Jun 2011
    Default How to remove VS SS V8 1995 Series 1 Power Steering Pulley without flange
    Hi all,
    I need some advice from the Guru commodore mechanics out there.
    I'm trying to put in new seals in a VS SS V8 1995 Series 1 power steering pump. I'm having a lot of trouble trying to get the pulley off.
    The pump pulley is a 2 stage type with no flange in the center.
    Since there is no flange like some of the modern pulleys, I can't use a flange type pulley removal tool.
    I do have a 3 jaw puller but I'm reluctant to go hard with it just in case I buckle and destroy the pulley.
    There is what appears to be a hex style hole and threading in the center shaft.
    However I'm assuming this is used only for installing the pulley back onto the shaft.
    I'm also assuming that the pulley is press fitted on.
    How do I remove the pulley without destroying it?
    Many Thanks
    Attached Thumbnails Attached Thumbnails How to remove VS SS V8 1995 Series 1 Power Steering Pulley without flange-vs-v8-power-steering-pump.jpg
    dinkum87's Avatar
    dinkum87 is offline Holden for life
    VR SS 5.0 MANUAL
    Mar 2009
    western sydney
    few commodores
    Feb 2011
    victoria
    it's pressed onto the shaft, not designed to be removed, to put a seal kit through the pump you don't need to remove this from the shaft.
    don't have a v8 pump on hand atm but it should be a similar saginaw design as pictured.
    clean up the back of the pump, you'll find a small hole there.
    use screw driver with the right diameter to fit in the hole, push the circlip out and then remove all the guts of the pump from the back.
    you may need to push the back of the pump down to relieve pressure off the circlip to get it out.
    Once the back plate is off there should be a small circlip around the shaft, remove this and the shaft and pulley come out in 1 piece.
    The 2 retaining rings are what you are looking for in the image of a blown up view.
    How to remove VS SS V8 1995 Series 1 Power Steering Pulley without flange-pump.jpgHow to remove VS SS V8 1995 Series 1 Power Steering Pulley without flange-saginaw2.jpg
  1. VT power steering pump pulley
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2011, 09:06 PM
  2. Power Steering Pulley Problem
    By sigmare in forum General Discussion
    Last Post: 22-07-2010, 12:31 AM
  3. Removing power steering pulley
    By maldotcom2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2009, 10:02 AM
  4. WTB: VN-VS V8 Power Steering Pulley Or Pump
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 29-04-2008, 01:21 PM
  5. How do I remove power steering pump?
    By sax in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2008, 09:20 PM
