Results 1 to 3 of 3
Thread: Noisy Power Steering Pump
    1TUFVS's Avatar
    1TUFVS is offline High Ambitions, Low Funds
    '95 VS Acclaim
    Oct 2010
    SA: The Defect State
    Default Noisy Power Steering Pump
    I've had my car for a few months now, but since I bought it the power steering pump seems to enjoy a good grumble every time I turn the wheel.
    Just wondering if I should get it replaced soon, or if it should be OK for a while longer.
    Cheers.
    "Race car driving is like sex - all men think they're good at it"
    -Jay Leno
    Quote Originally Posted by m1chael1o1 View Post
    i spray painted mine they look good, never been hassled by cops. I think i can feel an increase in power aswell
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    vs commodore
    Oct 2009
    Tamworth NSW
    Its common for the bush in the firewall where the steering cloumn shaft passes through it into the engine bay, to get noisey and dry ,which can then cause a moaning groaning type of sound when the steering wheel is turned.My VS was doing this badly when I first got it,and I took it to a couple of steering places,and was told it needed a new pump or rack etc.Then after reading on here about this dry bush,and the noise it caused,I though Id try spraying it with WD40 as I had nothing to loose,and I sprayed WD40 up into this bush from the engine bay side,and the noise completely went away away and has not come back,and that was a couple of years ago now.
    This noise did not sound like a dry bush at all,it sounded more like a stuffed power steering pump sound,so its worth checking this out and spraying some WD40 up into the bush and seeing if it goes quiet.You may find that you dont need a repalcement pump etc.
  1. Noisy Fuel Pump... Ideas?
    By Mick1988 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2010, 12:03 AM
  2. new pump 044 noisy and right fuel pressure?
    By vlosity in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-08-2009, 06:59 PM
  3. Noisy Water Pump VT - Strange
    By tone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2009, 08:29 PM
  4. Noisy Fuel pump VN Wagon
    By Disperse_daredevil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 06:03 PM
  5. noisy fuel pump
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-08-2005, 07:10 PM
