hi guys
my gearbox for a while now has had a whirring sort of sound like a worn out bearing n has gotten worse. It only seems to happen in neutral first second n third and the noise disapears when the cutch s pushed in (so it is between the clutch and the box). Dose any one know if this can be fixed easily by replacing one or two bearings or isit a fuller rebuild of the box. trying to do it cheap as dont have alot of money. have tried heavier oil in the box
Its a getrag... every one i have driven is noisey in the first few gears. Still drive perfectly fine though
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
