can some one tell me what the normal shifting rpm is going from 1st-2nd in a auto vr??
What do you mean "shifting RPM"? When you're driving an auto the gear shifts depending on how wide open the throttle is. That's what the throttle position sensor (TPS) is for. "Normal shifting RPM" as you put it could be anywhere between 1000-5500 at the point it changes gear.
If you're having trouble with your auto shifting gears funny its probably a wonky TPS.
yea from 1st to 2nd its goin up to 3000rpm
Could be the TPS or it might be slipping.
Does it go up to 3000 with no noticeable power increase to go with the rev increase its getting? If it does, your transmission is slipping.
Or if it just holds 1st gear too long, maybe a shift solenoid or the 1-2 accumulator piston in the auto crapped itself and is stuck in the bore or cracked.
yea no noticeable increase i had it serviced on wednesday and no change
If you had the service done at a garage, an auto "service" is just a new filter and a fluid change.. If your auto is slipping a service isn't gonna fix it. You can put one of those bottles of auto transmission conditioner from supercheap in that should make it a bit better, but that isn't gonna last long and you'll need a new transmission eventually.
It is more fun to select 1 on the shifter, then take off pedal to the metal and just hold it until it changes to second by default.
Definite red line+ in my VS wagon. These things scream. lol
Seeings the engine has done around 500,000 klms, I dare say THAT is why it blows blue smoke.
An engine/transmission in good condition has no problem revving as designed by the manufacturer as far as I'm concerned.
My comment was more to let others know that if you select 1 on the shifter and go hell for leather, that it will change to second gear prior to blowing up.
Similarly, if you are in neutral or park and hold it flat to the floor, the in built rev limiter kicks in prior to engine damage.
Obviously both the above are not recommended for everyday driving!
