Results 1 to 6 of 6
Thread: Help: dash light
    VS Executive 3.8l
    Mar 2011
    SYD
    Default Help: dash light
    Hi guys, my holden commodre VS has a problem on my dash. The battery light keeps coming on when i brake or step off the gas and when i accelerate up to 3,000 rpm the light goes away.
    Does anyone know the problem ? As I've already changed the battery and the light is still showing.
    cheers guys~
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    It could be the alternator not charging properly. May need to recondition/replace your alternator.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    +1 for alternator fault.
    vr berlina
    Aug 2008
    ShawtyNate's Avatar
    ShawtyNate is offline Kicker
    '94 Holden VR Acclaim
    Jun 2011
    Moree NSW
    i got a prolem when i start, that orange engine light stays on for about 2 secconds but then goes off. does anyone know whats wrong with that
    vr commodore
    Jul 2011
    south australia
    the best way to check the altonator is to get a multi meter and start the car and see if the battery is charging at low revs then rev it up a lil if the numbers dont go up then the regulator is faulty, but then again could be a problem with the running gear in the altonator, if that all is fine the there is a further fault
  1. check Tail Light dash light on
    By egadgetjnr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2009, 11:43 PM
  2. VX SS Dash Light Out
    By Slopehead in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2009, 10:22 PM
  3. Replacing dash light AND radio light
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 05:39 PM
  4. Dash Light Warning Light
    By Bongo in forum Electrical Wiring / Questions
    Last Post: 07-10-2005, 08:17 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
Tags for this Thread
