i recently bought a vs s2 but had to get a new auto transmition installed.the mechanic disconected the battery and now my radio wants a security code but i didnt get one when i bought the car.is it stuffed now and needs replacing or is there a factory reset to fix this?
The code is usually written in the owners manual well that's where mine was when mine did that if not u can get the code from Holden
You need to go to a Holden dealer to get the code,it will cost you $20-$30.The codes are written in the maintenance log booklet/owners manual that comes with the car,but since you said you didnt get one then you need to go to Holden.
Kind of defeats the purpose of a security coded radio?
check in your owners manual for a card that as the code on it this was suplied from the factory, also look in the manual on the inside of the back cover it is somtimes writen on the inside of the back cover or somthing like that. if you have no joy with that any privite mechanic will be able to plug into the computer and retrive the code from there rather than pazying holden to give it to you.
I think what cracka was getting at is if the radio's pin code is entered wrong 3 times,you have to wait a hour until the pin code can be entered again.
Heres what the VR workshop manual says about it-
If the security code is entered incorrectly 3 times,the display will show a ' - ' symbol.
The security code proceedure cannot be attempted again for approximately 1 hour when the number ' 1 ' will be displayed..
Also I found my radio pin for my VS written inside on the bottom of the glove box.Someone had written it in there.Ive heard of other people finding theres there also ,so it could be worth having a quick look.You might be lucky..
Radio code is stored in the BCM.
Your mechanic should be able to acess it with a scan tool.
TBH the best thing to fix that is removing the unit and installing a newer 3rd party unit. But if u seriously like it then yes check ur manual or you will have to go to holden and pay.
