Results 1 to 5 of 5
Thread: Would a tie rod end cause this?
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default Would a tie rod end cause this?
    Hi All
    Just got back from a 4000KM road trip around Victoria and around 600km out of Adelaide I started noticing the passenger side of the car seemed to be vibrating/knocking around a little bit which was causing the steering to shudder a little at 110 on the freeways.
    I stopped to check that the wheel nuts etc were ok but being in the middle of no where and wanting to get home I continued to drive.
    Now upon getting the car up on ramps today I have gone over the front end and all seems to be ok except the passenger side tie rod end's ball joint has completely collapsed/gone lopsided. would a bad ball joint be the cause of these symptoms?
    Praying for it to be something nice and cheap like that :P
    Thanks Guys
    (Also FYI I doubt it would be the wheel balance causing the shudder as they are all brand new tyres that were aligned and balanced before I left)
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Quote Originally Posted by someguy360 View Post
    Hi All
    I would instantly assume this is ur problem if you just had them fitted and balanced, sounds like they didnt balance them right, or a weight wasnt stuck on properly and has flown off.
    Reaper
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    If the tie rod end is gone, replace it and see if that fixes it. If not, +1 for the wheel out of balance, especially if it was recently done.
    Swap the front wheels side to side and see if does it then.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Mar 2008
    you are saying your ball joint has collapsed , im sure that would be causing your problems
    i'd replace that ball joint and tie rod end and you will need another alignment
