Results 1 to 4 of 4
Thread: Cleaning/Polishing Plenum
    VS Executive S2
    Jun 2011
    Frankston
    Default Cleaning/Polishing Plenum
    hey guys was just wondering if i chuck the plenum in a buckter of hot water will it cause any sort of damage to it? just took it off and im sure yuoll understand how dirty it is haha
    VS UTE, HT MONARO REBUILD
    Dec 2010
    if your wanting to clean the plenum before you polish it the best thing to do is buy some carby cleaner, or degreaser and spray it on and let it soak for a bit then just wipe it, scrape it out or blow it out with a hose or air compressor
    but the answer to your question is no it wont damage any thing soaking it in hot water for a while, if its the entire plenum body then make sure you remove the sensors and dry off the plenum after you pull it out of the water. Hope this helps
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    if it helps, it may be an idea to completely take the plenum off (the whole manifold really) and do it outside the car.
    you dont want any gunk falling down the runners into the motor.
    its also easy to do it outside the car, not leaning over the engine in an awkwards position.
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    VS Executive S2
    Jun 2011
    Frankston
    well ive take just the top cover plate off to give it a shine up and then saw just how dirty it was underneath and couldnt put it back in im OCD on that sorta stuff
  1. [VT-VX] Polishing the plenum on your ecotec
    By ANL53X in forum Holden Commodore How-To's
    Last Post: 12-02-2012, 07:16 PM
  2. cleaning plenum chamber
    By casper0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2011, 08:37 PM
  3. polishing inside of plenum/intake?
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2011, 09:24 PM
  4. cleaning, waxing polishing etc
    By 02DUBH in forum General
    Last Post: 09-01-2009, 07:11 AM
  5. Cleaning/polishing throttle body?
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2008, 05:14 PM
