Results 1 to 11 of 11
Thread: fuel smell in cab vr ute
    94 vr ute
    Jun 2011
    perth
    Default fuel smell in cab vr ute
    i just bought a 94 vr ute and from full down to half a tank it reaks in the cab of fuel , i looked thru manual and it had tank troubles from new so i took cover off and it had been braised up so car dealer i bought it off got repco to replace tank with 2nd hand tank and it's been back to them 3 times cause it still smells of fuel and they cant find where its coming from , any ideas?
    vs commodore
    Oct 2009
    Tamworth NSW
    Its mostly caused by split or broken fuel tank breather hoses in the fuel tank area,especially check the one that runs from the fuel tank to the purge cannister in the engine bay,it can split up in the engine bay area causing fumes to go back through the cabin...its a common problem with utes.Theres been plenty of people who have posted up about this problem and have fixed it..
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah this happens with my ute too. Plenty of threads on here mentioning the same thing. One bloke said it was a split in the tank seams and another had breather line issues. Both of which can happen to yours.
    vs ute
    Jun 2011
    pottsville
    Yep just had a problem just like yours found a hose disconnected at the tank rip up the front panel in the tub and see whats happening (only a couple of screws) if its a hose just follow it back or forward to the engine bay and presto if its at the tank end pull your drivers side seat forward and you will see a panel remove have a tourch handy and you will see where they go all the best any probs or more info PM me
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    check the o rings around the injectors as this will also give a fuel smell in the cab.
    i hope that helps.
    1994/VR
    Apr 2011
    vic
    yea m8 had the very smae problem for about 1 year and i fixed it 2 days ago
    take off ur inside pannel and u see a breather and u will probley notices its not connected or broken, the side pannel is on the right hand side of tub
    94 vr ute
    Jun 2011
    perth
    thanks , will pass it on to him and he can get it done , it has a rubber mat in the back and when i lifted it up the front panel didn't even have bolts in it
    97 vs manual ute
    Jun 2011
    bunbury
    yeah all the breather lines crack over time i had the same problem with a 93 ute i had and i had to replace all the hoses
    1998 VS Ute
    Jul 2010
    Perth Hills
    i have the same problem wiht my vs ute, excuse my stupidity but where are these breather lines and which hatch/hatches do i need to pull up? thanks in advance
    Making a 4 cylinder fast is like telling everyone your gay. At first you might suprise a few people but in the end, you're still a fag.
    97 vs manual ute
    Jun 2011
    bunbury
    the big flat panel on the floor of the tray the tank is under that also take of the panel behind the fuel filler. trace and replace the lot of them i did one hose that was cracked then acouple of weeks later had to take it all back out again so just do them all in one go for piece of mind.
    94 vr ute
    Jun 2011
    perth
    i took the panel off behind the filler point and the thin hose that comes out the bootom of that little half moon container thing thats clamped on down the filler alittle is curled up above it and zip tied there with a bolt srewed in the end of it , is that right?
    and the small hose on top of the tank that goes to that half moon thing is cracked alittle , should it be clamped to the tank cause its just pushed on
  1. vs ute fuel smell
    By Muzz the kiwi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2010, 10:24 PM
  2. vz fuel smell
    By davenmarcia in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-11-2009, 04:04 PM
  3. vs fuel smell
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2008, 09:01 PM
  4. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
  5. Fuel Smell
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-03-2007, 12:17 PM
