Results 1 to 4 of 4
Thread: Re-build machining costs for my 98 VS II (or III, not quite sure)
    1998 VS III 5.0 Manual Ute
    Apr 2011
    N.S.W.
    Default Re-build machining costs for my 98 VS II (or III, not quite sure)
    Hi all!
    I'm planning a re-build for my VS Ute. Its got the 5.0ltr GETRAG setup happening
    so I'm planning on pulling it down, stroking it out to 355, fixing it up and putting it together again. That ultimate goal is to have a strong, reliable everyday driver that will turn about 250kW once done. (and no I dont want to buy a later model 5.7/6.0 that will do it stock!
    My question is,
    1) how do I know if its a series 2 or series 3? Its manufacture plate says it was built in May 1998 which puts it right on the cusp. Is there any way to tell for sure?
    2) When I strip the engine I want a full machining job done on it, that is:
    -Cylinders bored and honed
    -Main bearing bores re-ground
    -Block and head decks re-cut cut (if needed)
    -Valve seats re-cut
    -Valve guides done
    -Heads ported a little
    -Balanced etc etc etc.
    Does anyone out there know roughly what this will cost to get done?
    Ive worked out the machining will probably be around the $2,000-$3,000 mark.
    Can anyone confirm that I'm in the ball-park here? I am doing the tear-down and re-assembly myself so thats not of concern. I'm just interested in what people might think of machining costs.
    Cheers!
    I prayed to God and asked him for a bike. But God doesn't work like that so I stole one, then asked His forgivness.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    With minor head porting inclusive in the machining costs, i'd say you're about on the mark to use work i've recently had done as a guide. Just remember that a good porting job can be quite labour intensive and therfore cost a quite a bit though
    VS3 S-pack M5
    Aug 2010
    Joondalup, WA
    If ur car still has its badges, then there will be a SeriesII or SeriesIII badge on the tailgate. Otherwise, I think the SeriesIII S's have got like a blue sort of zigzag trim on the seats and doors, whereas SeriesII ones have like a grey/red trim pattern.
    VY R8 & VN Calais
    Jul 2011
    Good luck mate will be nice once you get it all done
  1. Twin Turbo VS Ecotec Build **engine build in progress page 16**
    By IBLOWN in forum V6 Development And Modification
    Last Post: 27-12-2011, 11:57 PM
  2. VE rim machining ?
    By aussie7 in forum General
    Last Post: 19-07-2011, 10:07 PM
  3. Insurance costs for P platers + cracked engine mounts. (how to fix/costs)
    By Raremetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2010, 06:28 PM
  4. To build or not to build, that is the question?.....
    By andyman in forum The LAN Lounge
    Last Post: 11-03-2009, 12:07 AM
  5. Machining Rotors
    By old mans ute in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-02-2008, 12:44 AM
