Has anyone had any experience fitting corvette c4 brakes on vs commodores. The c4 calliper i am referring to is a pbr twin piston with a finned aluminium housing and looks very similar to the VS GTS. I haven't been able to find any part numbers to confirm it is the same calliper, but a search of a few different brake websites show it accepts the same pads as the VS GTS calliper and also has a 28mm rotor. The c4 however takes a 330mm rotor compared to 328mm for the GTS.
If possible I would like to fit the c4 calliper with the GTS rotors on my VS. I realise these brakes aren’t as good as the modern twin pistons available, but I would prefer to have original looking brakes.
* Does anyone know if the c4 calliper is compatible with GTS rotors?
* Are the twin piston callipers fitted as standard equipment on some of the higher level hsv v8s from vn – vs interchangeable?
i had the c4 style calipers on my vn, there are 3 types of the c4 caliper, the jl9 suited to a 12" rotor, a j55 suited to a 13" rotor and a gs that suited a 13" rotor but was a more smooth caliper and had corvette embossed in it. hsv used the j55 caliper, i dont know if hsv used the same (pretty sure they were)slide mount as the corvette but the hsv s had a left hand slide on the right and a right hand slide on the left, and they had a extension bracket as well, possably the same slides were used as the hsv calipers are front mounted and the corvette is rear mounted. hsv first used these calipers on the sv5000, and then on the vn group a, also on the gts-r and was a premium option on iirc vr vs as a second option to the harrop calipers. the 2mm difference doesnt make a difference when its on the car.
personaly imo the c4 caliper is a lot better than the vt type caliper, also recomend if your car doesnt have a 1" master cylinder put one on with the c4 calipers or it will be a waist of time.
you can also buy these calipers of pbr as a sports upgrade, they come front and rear, also with a bigger caliper and a ventilated rear rotor for the rear but not sure if they have a kit for the solid rear axel yet.
thanks for the valuable info Glenn l. I had been looking at the j55 callipers for the upgrade, did you use the corvette mounts.
im pretty sure they were corvette mounts, but you will need an adaptor mount to fit them to the commodore.
Where do you think the best place to track down an adapter would be?
I agree Reaper, they are a fair bit cheaper than buying locally and the gs calipers look great.
No idea - I got them from a busted up Clubby 5000i that I wrecked (one of the calipers had a broken mounting bracket). I'd just laser cut some more if I ever did it again. If there is enough demand I could organize some more but they would have no engineers etc.
Reaper
