Okay, driving home from work today my indicators stopped working and to make it worse there was a nice bright green cop behind me, got pulled over and nearly got out of a fine for not indicating around a round-a-bout..
Anywho, I've looked up past threads and followed some of their tips, here's the thing. My hazards haven't worked since owning the car (5-6 months) and i read that the windscreen wipers and indicators share the same spark plug thing. I tested the wind screen wipers and they are working fine, and went the car is unlocked via central locking the indicators work they just don't work, flash or sound when in drive.
What do you think the problem is and what is a cheapish way to fix it? Spark plugs?
Oh, and my hazards work now fine?!
Cheers!
I am assuming that when you said 'spark plug thing" you were talking about the fuse, if so then check all the other fuses in behind the driver side dash/kick panel and also check fuses and relays in the engine bay in the black box on the left hand side.
i never knew lights had spark plugs.
but as above take it to an auto elec normally these problems will be way more then just a blown fuse or globe.
Ok at the start you say your hazzards dont work then at the end you say they do um which 1 is it??
Has your indicators worked for the last 5-6 months??
I had a problem with a vr that when the central locking was pressed the indicators would flash no probs but as soon as you indicated there was nothing.
Found out it was a dodgy hazzard switch, replaced that and all was good again.
just replace the flasher can already... sheesh, spark plugs, windscreen wipers.... WTF
"Nearly" meaning you got fined for not indicating at a roundabout??
Since your hazards work fine I'd suggest your spark plugs are probably fine. I'd be looking at the center bearing of the tail shaft or rear brake pads. Both of those commonly wear out on old Commodores and give trouble.Anywho, I've looked up past threads and followed some of their tips, here's the thing. My hazards haven't worked since owning the car (5-6 months) and i read that the windscreen wipers and indicators share the same spark plug thing. I tested the wind screen wipers and they are working fine, and went the car is unlocked via central locking the indicators work they just don't work, flash or sound when in drive.
Cheers!
Reaper
The path of least pain for you would be an auto elec.
A competent mechanic should also have no trouble with this.
