Results 1 to 2 of 2
Thread: welded flywheel and ring bedding.
    96 VS executive series II 'S pack'
    Jan 2011
    australia
    Default welded flywheel and ring bedding.
    gday guys
    my vs has a getrag box and i had no idea it had a dual mass flywheel. i just thought it was two flywheels welded togethor, but ive seen another getrag and its the same without the welds. anybody have an idea as to why this has been done?
    after searching around for how to bed new rings all ive seen is that you do it for 70 or so kilometres. what i want to know is if there is an optimal way to bed your rings, such as what type of rpm to reach or hold upon first start up? or must it be done under load?
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    some one has welded the fly wheel caus the spring is broken and put a standard clutch. to save on money a clutch set up with a dual mass flywheel has a dapaning spring in the fly wheel
  1. VP Welded Diff
    By Tuff-VP-Wagzz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2010, 06:04 PM
  2. Bedding in VR disc brakes problem
    By kswenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2010, 08:17 PM
  3. Handbrake Bedding In??
    By 2005vzute in forum General
    Last Post: 20-09-2010, 11:33 PM
  4. What is the correct method of bedding in new pads?
    By faroogoo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2008, 05:34 PM
  5. 'Bedding in'
    By ssmate in forum General
    Last Post: 29-01-2007, 07:02 AM
Tags for this Thread
