Results 1 to 4 of 4
Thread: irratic idle
    96 vs calais series 1
    Apr 2011
    maroochydore
    Default irratic idle
    fella's car has been running a treat, but of late the idle is not right as i pull up to a light the engine almost stall's and then capture's itself again and seams to miss fire every now and again in drive, in neutral it idles a little higher of coarse and is better when driving it's smooth as. any thought's???
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Have a good look at the vacuum hoses. These can have a hair line split that will cause this. But really it could be anything from dodgy fuel to a coil pack?
    vn calais 5.0
    Jun 2011
    victoria
    Might be a throttle position sensor? Mine would not idle in drive when slowing down at the lights and had to have 1 foot on the gas and 1 on the break to keep her running..
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Assuming the plugs and leads are OK, the throttle body and IAC are clean and the coil packs and DFI are OK, I would remove the DFI and mounting bracket and clean the surfaces where the DFI mounts to the bracket (add a little more zinc oxide grease) and where the bracket mounts to the engine.
    A good connection to earth is important as the PCM uses the DFI to control idle speed (with the IAC) by altering the ignition timing.
    Mine used to almost stall when shifting from reverse to drive (you could feel the IAC trying to catch it) and this fixed it.
    I assume its a V6?
  1. Vr stalls irratic idle abs??
    By vpwagon19 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2010, 04:41 PM
  2. idle problems. won't sit at a constant idle.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 07:59 PM
  3. vt v6 not idle
    By Corey walker in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-09-2009, 05:49 PM
  4. 4k idle?!
    By markER717 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2009, 12:47 AM
  5. Idle RPM
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2007, 06:53 PM
