Results 1 to 13 of 13
Thread: Dash lights problems
    VS UTE, HT MONARO REBUILD
    Dec 2010
    Cool Dash lights problems
    hey guys, slowly restoring my ute back to its former glory but have a few problems that im not 100% clear on
    1. the seat belt light doesn't come on on the dash (dunno if my ute even has one of those sensors in the belt for the light to go off)
    2. the Low fuel light doesn't come on at all
    i know that the fuel light is a common problem and that there is no simple fix
    any help would be great
    mx kid's Avatar
    mx kid is offline 5th pinned
    VXII CLUBSPORT
    Apr 2009
    Perth, WA
    In my VS ute the seatbelt sign used to light up for about 3 seconds when you started the engine whether you had the seatbelt on already or not.
    Guess its more of a reminder than anything.
    VS Berlina/ KJ Verada
    Sep 2006
    Since when did VS's have seat belt warning lights? Was this a later model addition or a ute special??
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by SWE11L View Post
    thay dont
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    i think the later model vs has seatbelt warning, its after a certain vin number. early model vs has air bag warning (for L3 clusters anyway)
    did you try and replace the globes?
    vs commodore ute
    Jan 2010
    nsw
    hey mate do them lights come on when you put your car on acc? if not they may be just blown
    Dec 2010
    na the lights don't come on when the key is turned to acc, also i think that only the S3 VS had the seat belt warning light but don't hold me to it.
    vs commodore
    Oct 2009
    Tamworth NSW
    My VS has a level 2 dash,and has the SRS airbag warning light on the right side of the dash that comes on for 3 seconds and then goes off again each time the car is started.It doesnt have the seatbelt warning lamp on the right side though.Ive noticed that none of the early VS's (1995 models)had this seatbelt warning light.Just the later model VS's have it.Im not too sure about the level 1 or level 3 dashes,but I do know the later VS's with the level 2 dash have the seatbelt warning light,Im not sure if they still have the the SRS light as well though.Ive got a couple of them sitting around for spares,I will have to check them out ..
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    my 97 series II clalais has the seat belt one, it only comes on for like three seconds and goes off though
    vs commodore ute
    Jan 2010
    nsw
    Quote Originally Posted by Shooter 88 View Post
    hey mate just pull your dash out and check the lights to see if they are blown
    VSII V6 Auto Berlina Wagon, VY SS Crewman
    Oct 2007
    Quote Originally Posted by calais24/7 View Post
    Yep, my VSII Berlina does the same. Don't know if it is supposed to stay on until I fasten the seatbelt. Don't care either I'm just happy it doesn't beep at me.
    VSII V6 Berlina Wagon, Auto
    VY SS Crewman Ute, Auto
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Bit of a late update but have seen some of these threads around so thought id share this information.
    All VS's after Jan 96 should have a working Seatbelt Warning Light displayed for 5 seconds, this is because of ADR Changes at the time, instrument clusters from Nov 95 had the light module fitted but didn't have the circuitry on the cluster and had no bulb fitted, from Dec 95 all the required changes were made to the clusters but it was still not used, they then released a revised Trip Module(button assembly) which had the extra line to short the light for 5 seconds from Jan 96.
    The light is basicly shorted between the Trip Module and the Airbag light by the trip module on key turn, as the airbag light stays on for the same amount of time.
    Dec 2010
    thanks The1, most of my light problems are solved now, just need a scan tool to get rid of the airbag light.
  1. Changing VE sv6 lights to HSV lights. any problems with projector lights
    By SV6.VICTORIA in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-06-2011, 01:39 PM
  2. Vx dash lights flashing & other problems
    By Glenoz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 01:42 PM
  3. No interior lights, dash lights or elec windows vk
    By ported in forum Electrical Wiring / Questions
    Last Post: 18-09-2006, 05:10 AM
  4. No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 10:36 AM
  5. Custom Dash + Coloured Dash Lights?
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2005, 09:08 PM
