Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By NickVR
Thread: GTS Hydratrak LSD Problem
    VS II Berlina & BMW E30 318 iS & VS II Manual GTS
    Mar 2009
    Rosebud / Mornington Peninsula / Victoria
    Default GTS Hydratrak LSD Problem
    Hey guys/girls
    Last night was cruising around no troubles at all. Except the ABS light came on. Thought nothing of it since the car was still driving fine... Later that night, came home and reversed the car into the drive way. locked it and went inside to sleep.
    Come out the next morning to go to work. Started the car. Let it warm up for a bit then went to drive off. Put it in 1st and let the clutch out only to go nowhere.
    At this point I'm thinking wtf?? Got another lift to work and left it all day.
    Jack the car up after I got home from work, started it, put it in gear and noticed that only 1 wheel was spinning...
    Then I saw this.
    The whole shaft has just slid out by the looks of it???!?!?!?! WTF!!??
    How could this have happened?
    Could there be any damage?
    Easy fix or am I looking at a new diff/rebuild?
    Ideas?
    Help much appreciated.
    Thanks!
    vr commodore
    Jul 2011
    south australia
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    I would be getting that towed to a diff specialist.
    Ronald Reagan (1986)
    Mar 2009
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    No damage to the rear cross member that could cause this. It's common on the early IRS cars for the crossmember to crack/break.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    VS UTE, HT MONARO REBUILD
    Dec 2010
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    +4, ^^^^^^^^^^^^^^^^^^^^^
    Also check the other end of the CV, try and not drive it.
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    Lol the good old IRS fail,love my live axle
    What the others said is true though.
    Mar 2009
    Think your right peeps, had a good look at it today. Took the drive shaft out and it seems fine. Pushed the flange back into the diff and bolted it up. It's alright driving it forwards but if I reverse the car the wheel seems to pull out alot more and look like its got heaps of camber :S Will look closer for a crack tomorrow. Could it have bent the trailing arm? So glad its not the diff though. That would have been expensive. :/
    Thanks for all your help so far!!!
    vs commodore
    Oct 2009
    Tamworth NSW
    These IRS setups are a joke and are dangerous, and shouldnt be trusted if you are a "spirited" driver who actually likes to drive their car quickly..I dont know why they made these IRS setups so weak.Ive got a mate who had the complete left side of the IRS assembly collapse in on his HSV VS,all he was doing was going around a corner fairly hard and fast..hes lucky it didnt cause more damage to the car or even injure someone, as it took him completely off the road when it broke/collapsed. As mentioned,thank god for live axles.You wont break a live axle setup in a hurry just from cornering hard....
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Can't agree with Brett_jjj. I've ran hundreds of racing kilometers at Sandown and Calder during Murcott Driving High Performance driving days in my Calais and never had a problem with the IRS.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I'd say It's not a problem you'd run into all the time but it's one that comes up occasionally. As long as you can get the camber right the IRS isn't a bad unit.
    cheap one on eBay -
    http://www.ebay.com.au/itm/calais-st...item4aac914b83
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by BlackVXGTS View Post
    Yeah,Id say that it would only be the odd IRS unit that turns up faulty and gives trouble ,Ive only heard of a couple actually collapsing,but I have heard of a lot of stories of them being cracked etc, luckily most owners notice the odd looking camber or whatever,and find the problem before it gets worse..I still dont think Id like to trust it at a track day though.Id definitely want to inspect it real good first at least..
  15. #15
    Mar 2009
    Thanks for the ebay link! Might pick up it. Yeah lucky I sused mine out before it got worse. Could have been pretty bad if it collapsed while driving :S
    Thanks for all your help everyone! Saved me from taking it to a mechanic and paying big labor rates once again!!!
    A+++ for this community.
  16. #16
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    Just a quick question have you had a camber kit installed within the last few months?????
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
  17. #17
    Mar 2009
  18. #18
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    If you have the ass of the car really low and have corrected the camber problem with Twin Camber kits. The axle can smack into the diff center over a bump causing the end of the axle to mushroom and drop the retaining surclip and allowing the axle to come out.
    Zapp
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
  19. #19
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    nice pics there zap. Intersting information in this thread, wonder if the general populus is aware of these issues with lowering irs commos.
    Reaper
  20. #20
    zapper-l67's Avatar
    VX Calais
    Jan 2010
    Western Vic
    Opps should of mentioned the pics aren't mine I borrowed them from a mate..
  1. VT HSV GTS Hydratrak lsd diff
    By boostboost in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2010, 11:08 AM
  2. hydratrak diff on vr?
    By VZHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2008, 09:33 PM
  3. hydratrak help
    By 98berlina in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2006, 07:39 PM
  4. Hydratrak???
    By Morgasshk in forum General
    Last Post: 04-07-2006, 04:54 PM
  5. Hydratrak diff problem
    By dirtly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2004, 12:02 PM
