Results 1 to 4 of 4
Thread: brake Pedal Problem VR
    vs ute
    Mar 2007
    Post brake Pedal Problem VR
    I've just finished replacing the intake manifold on my vr v8, i now have a brake pedal that feels slightly harder and travels a bit more.After crawling all over the motor again, I could barley make out that the spring clip that needs to be squeezed together that goes over the booster to manifold hose is not on. even thou the hose felt like a tight fit do you think this would be the problem???
    vr commodore
    Jul 2011
    south australia
    ther could be one of 2 options, one test bleed the brakes and see wat happens after, and secondly, put that clip on as their maybe a small amount of air sneaking out, it may appear to be a close fit but its the same with a radiator hose, it is a tight fit but u still need that clamp on, try that and see how things go from there
    vs ute
    Mar 2007
    vs commodore
    Oct 2009
    Tamworth NSW
    You can check if the booster is working properly and getting vacuum by firstly, with the engine off,pumping the brake pedal several times to deplete any stored vacuum in the booster.Then whilst holding in the brake pedal,start the engine,the brake pedal should sink in a bit more as the engine starts..
    Also with the engine off,the booster should hold a small reserve of vacuum,if you pump the brake pedal with the engine off,you should get 2 -3 pumps before the vacuum is depleted and the pedal gets harder to push in..
  1. alright so, brake pedal = parkers on front and rear brake light. head lights on and..
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2011, 08:29 PM
  2. brake lights not coming on until brake pedal almost to floor
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2010, 07:11 AM
  3. Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 09:01 PM
  4. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  5. Low brake pedal.
    By edgar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2005, 12:25 AM
