Results 1 to 9 of 9
Thread: Engine RPM dips on cold start
    SKNOT9 is offline All hope is gone
    VS series II Acclaim
    Feb 2007
    Lobethal, South Australia
    Question Engine RPM dips on cold start
    Hi guys. I have been having this problem which has been gradually getting worse, to the point of stalling now. When i start my v6 auto VS the engine rpm dips for about 3 seconds straight after it has started. It now stalls if its a really cold morning. If I turn it off straight away and start it again it is fine and starts normally. If i have left it for a couple of hours, once again it starts normally, its only if i havent started it for a day or 2. Has anyone had this problem before? recently serviced, cleaned IAC valve. Also, when i put on a bit of throttle to help the situation when it is dipping, it doesnt really make much difference, it will still dip to about 500-600rpm, which tells me it is probably not the iac valve because as soon as you put on some throttle, it shouldnt have any effect anyway. Someone help i have run out of ideas!
    VP Exec
    Jun 2005
    Leaking injector(s)?
    If you remove the rail and run the fuel pump - bridge the relay or turn the key on and off a few times you might be able to see which one(s) by wiping the injector tips with a piece of paper or even a finger if they/it are bad.
    Another fuel pressure leak, possibly inside the tank. You would need a gauge to check the pressure but if you trurn the key to on then off, maybe a couple of times, to build fuel pressure before starting then the car starts and idles OK that would be a clue.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Feb 2007
    ill check out the leaking injectors, i have tried turning the key up a few times to build pressure but it doesnt help. Cleaned out the throttle body and plenum chamber, didnt help. Someone has said could be a maf on its way out, is this possible?
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    VS Spac 5spd and r32 skyline 5spd turbo
    Sep 2010
    Mount Gambier
    exactly the same as mine. does your revs rise when you push the brakes in when you are in park?
    Feb 2007
    VP Exec
    Jun 2005
    Quote Originally Posted by reeceo View Post
    That will be a leak in the brake booster somewhere. Possibly the booster itself or the one way check valve.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Generally this issue is a memcal tune one and can be easily fixed with an update.
    Holden Changed some of the cold start fueling in some memcal versions about half way through the vs series, they leaned the fueling out below 20deg C coolant temp, no idea why they did this but in winter cold starts the engine now chugs for a second or two when first starting up but doesn't do it till it cools right down again the next morning, summer time its unaffected as the coolant doesn't get below 20deg.
  1. vs ecotec hard to start engine cold
    By baza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2011, 04:52 PM
  2. engine makes a loud click wen starting on cold start HELP
    By tye730 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-02-2011, 12:24 AM
  3. cold engine start trouble
    By grpa_ss vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-12-2009, 06:32 PM
  4. VP engine knocks on cold start
    By muggie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2006, 11:44 AM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
