Results 1 to 13 of 13
Thread: rear suspension
    VS UTE, HT MONARO REBUILD
    Dec 2010
    Cool rear suspension
    hey guys, Im going to be replacing both the upper and lower trailing arms either this week or next week depending on free time, but i was just wondering what you guys think is the best way to replace these, that is jack up the diff whist car is balanced on jack stands, drop of one trailing arm at a time and replace. what do you think is the best way.
    all opinions welcome and thanks for any help
    Dec 2010
    ALSO, instead of making another thread, my power steering pump has a leak, no grinding sounds or squeaks it works fine it's just leaking from the back of the pump any ideas if i need to replace it or if its something simple like an o-ring or loose hose?
    VN Wagon
    Feb 2005
    Dec 2010
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by Shooter 88 View Post
    It will be the rear main seal in the back of the pump. The hoses are on that tight they dont leak. Buy a new or refurb pump with all new seals, i did cause i could not get the retaining clip out of the back of the pump. New GM pump for $140 off ebay.
    A little How to i did if you need help changing it.
    Ecotec Power steering Pump Replacement
    Dec 2010
    thanks for that mate, Im thinking that more then likely that is going to be the case, but with a little luck it could be a loose hose as the previous owner changed the motor over so he might not have done the line up as tight as it should have been.
    Dec 2010
    well i just went outside and check the hose and unfortunately for me it's tight which means im more then likely in for a new PS pump, but ill pull it off during the week and see if it's something i can fix up my self
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Shooter 88 mate first just check to see if its one of the power steering lines either the low pressure return pipe or the high pressure pipe one of these could have a leak,my return line had a very small hole in it which made a lot of fluid still leak out heavily
    Dec 2010
    well i just got my parts in the mail today cost me $160 all up which i think is great as i got a quote for just the bushes on the lower arms for $110 and thats if they werent damaged from the beating they have copped over the past half a year and possibly longer with broken bushes.
    vs commodore
    Oct 2009
    Tamworth NSW
    Its pretty rare for control arms to be damaged from worn bushes.Ive only ever come across a few that werent fit for rebushing.
    Jul 2008
    Quote Originally Posted by Brett_jjj View Post
    My last set were crack nearly completely through on both sides around the bush, Bush was fine arms weren't
    vs commodore
    Oct 2009
    Tamworth NSW
    Your car has had a hard time at some stage by the sound of that.Ive only seen problems with these control arms(cracks etc) on the speedway cars my mate drives.Were always replacing bushes or fitting complete arms on these cars as they constantly get thrashed and seem to tear out these bushes pretty quickly....
    Jul 2008
    Yes i do give it a hard time. I love my corner speed.
  1. Vk Rear Suspension
    By VK SL 3800 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-12-2010, 07:22 PM
  2. VP rear suspension
    By wagonist in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2009, 02:26 AM
  3. VT/VX/VY/VZ - FE2 Rear Suspension
    By Kung-Foo-Kamel in forum Parts And Other Items For Sale
    Last Post: 12-12-2007, 10:27 PM
  4. vt rear suspension
    By brunorm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2006, 04:46 PM
  5. Ute Rear Suspension
    By pottsy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 07:32 PM
