Results 1 to 9 of 9
Thread: Question about the VS Ecotec intake manifold.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Default Question about the VS Ecotec intake manifold.
    Im currently tearing down a VS Ecotec plenum and intake for some extreme cleaning, boring, polishing. Only the inside ofcourse :P
    I took a look at the intake. Saw this spring:
    What is it, what does it do. I cant remember the size of the whole in my MACE 12mm spacer, but would the spacer effect the operation of this?
    Ill give you a quick run down of what im doing to see if i can do anything to this "thing".
    Iv got a 69mm MACE throttle body, 70mm AFM, custom piping from box to TB. Also have the MACE 12mm spacer and 12MM insulator. Im currently sanding and polishing the inside of the plenum and also porting the TB hole to suit my new one.
    Then i was planing to do pretty much the same on the manifold, except port the holes from the runners to suit the plenum (as you have seen, some times its not a nice finish on the inside) and port the outlet to the heads.
    So back to the original question, what is it? What does it do? And can it be modified for any reason. Thanks.
    VS Berlina V6
    Sep 2008
    VS
    Jul 2010
    Can you please explain this part abit more? As i dont know to much about the ecotecs, i will however do a search on this name you gave me. Cheers for your help.
    VS
    Jul 2010
    Cheers, found out what it does and so on. Best bet, as you said, replace it. But also red, a oil catch can can come in handy. Just hope i can hide it as i have never liked that sort of -keyword- shit.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    That spring retains your pcv valve (positive crankcase ventilation). Essentially its an emissions control device which recirculates hydrocarbons produced in the crankcase back through the inlet manifold so they are drawn back in with the inlet air charge and combusted in the motor, rather than discharging into the atmosphere.
    Remove the spring and then you will be able to remove the pcv valve by pulling straight up with a pair of long nosed pliers. To determine whether a pcv valve is functional, just shake it. If it rattles, its fine, if not it needs replacing.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    VP Exec
    Jun 2005
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    if it doesn't rattle, soak it in petrol to clean it out. if it still doesn't rattle then replace it
    Body by Holden, Soul by Brock
    the Legend will live forever
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by immortality View Post
    Thanks, Just what I needed to know
  1. [QLD] Hand Polished Ecotec V6 Intake Manifold Top: Will Post Aus Wide
    By redvs2 in forum Parts And Other Items For Sale
    Last Post: 11-10-2011, 11:45 PM
  2. 96 VS (ECOTEC) Air-Intake Manifold Plenum ####ING FILTHY
    By Nessie1996 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2011, 03:54 AM
  3. Creating a custom intake manifold ecotec v6
    By GTP 85 in forum V6 Development And Modification
    Last Post: 26-03-2011, 04:06 PM
  4. [Ecotec] Ecotec intake manifold, restrictive at 291rwhp
    Last Post: 07-12-2010, 05:21 PM
  5. ECOTEC intake manifold
    By Steve3800 in forum Raptor Superchargers
    Last Post: 02-12-2008, 09:22 AM
