Results 1 to 8 of 8
Thread: Replacing radiator and thermostat vs v8
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Default Replacing radiator and thermostat vs v8
    Alright so i finally got my new radiator. was going to put it in today but the weather is just too shitty. Anyway replacing the radiator isnt a drama, but i want to flush the whole system out before i put the new one in, can i just jam the hose where the thermostat goes? And just let the hose run for a while lol? And where abouts are the bleed screws? Or if someone has a ellorys manual or something and could scan/email the pages that would be really good
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You need to reverse flush by jamming the hose into the lower radiator hose connection and letting it run out the upper radiator hose opening (before you install the thermostat). There are no bleeder screws on a Holden V8. Just fill the radiator and start the engine with the radiator cap off and the heater set to hot. As the bubbles appear in the radiator cap opening, the level of coolant in the radiator will drop. Keep topping up the coolant until it looks like overflowing then replace the radiator cap. Fill the overflow reservoir with coolant to the hot mark, and top it up over the next couple of days as any air left in the system is purged.
    calais24/7's Avatar
    Jul 2009
    thanks heaps for that mate, was looking for a bleeder screw and couldnt find any so that'd be why lol. going to have a go tommorow hopefully the weather is good. Also hope it doesnt take to long
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If u have to get any bits, stop at holden and get a new o ring for the thermosts housing($1.50 i think), if not dont worry much. Put some blue silicon or someyhing in with the o ring when you seal it all back up regardless, i always find they weep otherwise. Shout yourself a couple new hose clamps while your at it.
    Reaper
    calais24/7's Avatar
    Jul 2009
    didnt think to get that, ill try rarespares, their only a 10 min drive away anyways. Cheers for that
    calais24/7's Avatar
    Jul 2009
    is there anything else i can use other then that high temp silicone? Dont wanna buy a whole tube and just leave it sitting around and probly never use it again lol
    VrWagz1's Avatar
    May 2008
    wollongong
    You dont have to use high temp stuff, as its only gonna get to 120C max. I just used standard blue silicon, if not you could get one of those multi fit thermostst housing gaskets and just put that in there. But i have just used standard clear silicon too before aswell, not sure on the long term implications of that would be but it seems ok.
    However, you could just use the factory o ring with nothing else and see how you go. Im sure they dont all leak, I just had alot of trouble with mine even with a new oem "o ring". It wasnt a big leak, which was the problem. I kept overflowing the coolant overflow bottle and couldnt find out why, all it was a weeping around the thermostsat housing that kept causing the system to prematurely lose pressure when the engine was turned off and not sucking the coolant back out of the overflow as it cooled.
    Reaper
    calais24/7's Avatar
    Jul 2009
    Right well i found some sort of black gasket glue and though that would be better then nothing. When i pulled it out it had the o ring. I bought a tridon replacement, before you mentioned holden do them for like 1.50 . the tridon one cost me ten bucks just for the bloody o ring. Anyway i put the o ring and a gasket and sealent stuff. So it shouldn't leak. Ill keep an eye on it over the next few days. Cheers fro all your help mate
  1. radiator flush/ thermostat advice please?
    By dogsbody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2011, 07:30 PM
  2. thermostat problems...replacing ideas?
    By hussy88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2011, 10:45 PM
  3. Replacing thermostat, help please.
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-02-2010, 05:57 AM
  4. Replacing VY Radiator
    By kiwiss5L in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-01-2009, 09:27 AM
  5. Prices 97 VS radiator flush & thermostat
    By MaC77 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2008, 10:00 PM
