Results 1 to 5 of 5
Thread: help with motor....
    Vs Berlina Series 2
    Jun 2010
    Default help with motor....
    so recently ive had troubles with my car.... ill be cruising doin 60km and my motor would just stall and completely die ?? it then wont start for a few gos...also sometimes does it when im just sitting at a set of lights i will go 2 take off and it will just die and wont start once again... any1 know why ??
    any help will be good
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    First do a code check and see what comes up. Also next time it does it, pour a heap of cold water over the crank angle sensor. If it suddenly starts, this is the fault.
    I'd be doing these two things first.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Same thing happened to my VS a while back. Turned out to be the DFI module.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    Vs Berlina Series 2
    Jun 2010
    yea ive tried the crank angle sensor thing and its not that... Superchargedvs6 did u have 2 replace the dfi module ?? its going in for a service 2moz so hopefully they can find the cause
  1. Motor stalls after secting drive when motor is cold.
    By dags061 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-01-2011, 10:38 AM
  2. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  3. wanna swap s1 motor for a s2 motor in a vn
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2009, 05:55 AM
  4. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  5. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
