Results 1 to 14 of 14
Thread: VS indicators not working
    VS Executive Series II 5spd man
    Aug 2010
    Default VS indicators not working
    Hey, the title explains my problem the indicators decided to stop working, for what reason i dont know, but i sussed out the fuse even tho it runs off the same fuse as the wipers and they are all ok. So i checked the relay, also all ok, i have no idea why it would just stop working, the high beam works on the stalk just not the indicators. So any ideas or knowledge would be much appreciated!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try pressing the hazard button a few times - if this plays up it kills the flashers. This is a common problem.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Hi bud
    If you press you're Hazard Light button, will the indicators work?
    On the Relay, are the 'prongs' burnt out ?
    When you try to indicat Left or Right do you hear any Clicking sounds to know if its working, but with no lights?
    It's possible that the wires behind the fuse board may have burnt out for the indicators, (doubt it tho)
    You might have a bad wire somewhere thats shorting out,
    If you have a Towbar, you most likely will have the Trailer Harness for it.. A lot of issues is caused by it, over time it gets old and shits out..And causes problems.. Like mine did LOL
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    92 vp executive v6 auto
    Jan 2010
    deception bay queensland
    had the same problem with a mates vr crawled all over it for days ended up be a faulty hazard switch
    Aug 2010
    hey guys,
    i tried the hazard button nothing works there either, i checked the wires behind the stalk nothings burnout or anything, the prongs on the relay are fine, i even chucked a new one in just to see and still nothing. yeah ill just have to start tracing wires i guess
    Aug 2010
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Quote Originally Posted by VSCHASE View Post
    i might replace the hazard switch then see if that makes a difference
    Better yet, unplug it.. And see if the indicators will work
    Aug 2010
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by Dum*P*ster View Post
    just did and it did nothing
    That's because the indicators are wired through the hazard switch.
    Did you try another flasher can? (looks like a relay)
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Ahh not good,
    The main places I firstly look for faulty wires.. is in the rear, go from the the taillight wires to the loom plug, and see if the plug is rooted or causing issues.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Quote Originally Posted by RX25SE View Post
    Ahh, didnt know! Learning new things everyday,
    so advice now is, grab a new button when you can
    Aug 2010
    flasher can? i tried another relay but not a flasher can
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Maybe replace the indicator stalk? If that breaks the hazard lights will not work as far as I know...
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Maybe the same thing?
    It's the thing that makes the (causes the on/off action) clicking sound when the indicators flash.
  1. vs ute indicators not working
    By bhagl1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2010, 03:51 PM
  2. Help! Indicators not working!
    By LittleMissVE in forum Electrical Wiring / Questions
    Last Post: 05-04-2010, 11:57 PM
  3. HELP!! indicators not working
    By 17UCK! in forum Electrical Wiring / Questions
    Last Post: 13-10-2009, 07:25 PM
  4. VR Indicators not working
    By Muik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2008, 02:24 PM
  5. Indicators Not Working?!
    By 1991_Vn2nV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 06:07 PM
