Results 1 to 5 of 5
Thread: power steering problem?
    VR 1994
    May 2011
    Central Coast NSW
    Default power steering problem?
    Hi
    I have a problem with my steering.
    When the steering is straight or turning easy corners it's fine
    but when i have to turn 90 degree turns or more where the steering is
    nearing "full lock" it tightens up real bad and seems to lose the
    "power" in the steering?
    The Power steering fluid bottle is just under the "full" line
    and looks pretty much red still and clean.
    Would it be the Power Steering Pump thats faulty or something
    in the Suspension\Steering part of things (or something else
    entirely?)
    Thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    It could be a number of different things causing that.Id take it to a steering/suspension place and get them to check it all out,and get them to give you a quote on repairing the problem.Get back to us here first before committing to getting the car repaired,let us know what theyve said,and someone here will be able to give you more advice once we know more about whats wrong.Cheers.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Can you give a bit of background on this problem like: how long has this been happening...is the car high mileage....have you hit any gutters etc recently.
    VR 1994
    May 2011
    Central Coast NSW
    I only just bought the car a month ago.
    I drove it home about 30KM's and have since taken it for a few spins (another 20Kms) as it's not rego'd atm and i definitely haven't hit anything? It's been like that since i got it. it's only done 215,000Km's? Normal steering feels fine as til it hits that point?
    Thanks
    VR 1994
    May 2011
    Central Coast NSW
    I was planning on getting my mechanic to have a look at it and fix it
    as part of the RWC Inspection i'm getting him to do for rego. He's trustworthy so i'll put it in and see what he says
    and get back to you all!
  1. VZ SS Power Steering problem
    By loudvtss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-05-2012, 07:28 PM
  2. Power steering problem
    By Meant to be a manual in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2010, 10:35 PM
  3. power steering problem
    By dylanstone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2010, 08:30 PM
  4. power steering problem
    By crazstaat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2009, 08:32 PM
  5. problem with power steering
    By bagmup in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2006, 08:10 PM
