Results 1 to 11 of 11
Thread: Installing rear speakers help
    ozzie_online88's Avatar
    ozzie_online88 is offline I'm No Superman...
    2003 VY S1 Exec
    Sep 2005
    Adelaide, South Australia
    Post Installing rear speakers help
    Im wanting to put my 6x9's in the back of my vr.First question..I had them in my old vn with vn speaker mounts so do you recon I will still be able to use the mounts or will I need to buy ones for a vr? Second question..how do I remove the stock speakers? I have had a play around with them but I cant seem to work it out.(im not to flash with cars).
    Btw I had a quick search for answers to my questions b4 I posted this, so if my questions are in another thread please post a link to it. Thanx
    2003 VY S1 Exec
    Sep 2005
    VSAccCom Guest
    Hey, i have a VS and replaced my stock rear speaker on sat,
    1. Undo the bolt for the child restraint, along with the plastic screws(they should just pop out with some force)
    2. Remove the bottom seat, its just cliped on pull up and backwards, should come off then with some patience
    3. There should be one bolt holding the back portions of the seat, undo that and remove the backs.
    4. There are 3 Plasctic type screws, a bit of force and some long nosed pliers do the job, once that is done just remove the back panel covering the speakers and there u have ur stock speakers, as for 6 by 9s i dont think they will fit in custom holes.
    VSAccCom Guest
    As for the front covers they should just pop out by the looks of things( i havent actually removed mine) but yeah hope it all helps
    2003 VY S1 Exec
    Sep 2005
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    The VR Front covers are actually the door trim believe it or not! the trim is fitted to the covers to make it one piece. There are instructions elsewhere on the forum on taking these trims off.
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    vr commodore acclaim sr2
    Oct 2005
    Gold Coast
    i just put in 6 x 9's in the rear of my vr using mounts i bought from strathfield car radio for about 15 bucks your vn mounts should fit i believe
    VS Berlina 3.8 M5
    Aug 2005
    Geelong, VIC
    just put some mounts in and and maybe cover them with carpet so they look good. as for the front trims
    1. theres two screws at thew bottom
    2. remove the plastic cover on the hadele and unclip the elec mirror switch and screws
    3.remove the airevents toward the front of the vehicle and
    4. finally u need to unclip the little door lock thing-y by pulling the red tab towards your self and the lock/unlock button shound come off, then simply a matter of removing the trim (be firm as it is held on by clips)
    curious Guest
    hey i got aHolden Calais VR 1993, how big are the front and rear speakers????
    people said 6'' both... i wanna put 6.5 in the front, and 6x9's in the backl
    with the 6.5's fit
    VR Calais
    Apr 2005
    front ones are 5.25 or something, at any rate you'll need to cut the plastic back housing behind them if you want to fit 6.5's
    you can either use a hacksaw, or a power drill and steak knife like I did. they'll fit fine after that. window won't bump into it when fully down.
    VS Belina Series 2
    Feb 2006
    Ey i wouldnt bother going to all that trouble cuttin the pods behind the door trims jus for the the extra .5 of an inch, if u get 6" splits they will fit straight in, ive done that in my car
  1. VP Wagon : Installing Rear Speakers.
    By clueless in forum Car Audio
    Last Post: 16-02-2010, 09:27 PM
  2. installing speakers in vn
    By haynze in forum Car Audio
    Last Post: 20-07-2009, 08:21 PM
  3. Installing Speakers in rear
    By Pretender in forum Car Audio
    Last Post: 08-04-2006, 02:51 AM
  4. installing VY 6x9 Speakers
    By cb1177 in forum Car Audio
    Last Post: 08-01-2006, 11:18 PM
  5. Installing front speakers into a VC.
    By SSGEN-3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2005, 10:15 AM
