Results 1 to 4 of 4
Thread: vr power steering leak
    vr wagon v6
    Jul 2011
    brisbane
    Default vr power steering leak
    have had a very small loss of power steering fluid ever since ive had this car for the life of me cant locate its source anyone know something bout that? thanks
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    There are several place fluid loss can occur.
    Probably the most common is the steering rack leaking fluid into the rubber boots.
    If the boots are in good nic and not cracked or perished, you will have to cut the cable tie from the end of the rubber to see if there is a leak there.
    Replacement cable ties are common at many stores.
    If you are only needing to top the power steering bottle up once a month or so, I would put a cap or two of brake fluid in as well.
    The brake fluid will swell the rubber seals and usually stops the leak for some time.
    There is also a stop leak power steer fluid available.
    vr wagon v6
    Jul 2011
    brisbane
    VR Berlina
    Nov 2009
    west suburbs, melb
    let us know how the brake fluid goes
  1. vr power steering leak
    By Mr spinalot in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2010, 01:44 PM
  2. VK Power Steering Leak
    By D34N in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-03-2010, 07:47 AM
  3. vs power steering leak
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2009, 11:44 PM
  4. VN power steering leak
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2008, 05:21 PM
  5. Power steering leak?
    By Sons1vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2005, 11:03 PM
