Results 1 to 8 of 8
Thread: VR Statesman Will not turn over
    vn ute
    Jul 2010
    adelaide
    Default VR Statesman Will not turn over
    Plz can someone help? I have a VR Statesman 5L which just will not start. I turn the ignition and the fuel pump operates no worries but the motort does not turn. I called the RAA out and he said he dont know what is wrong. AQfter he left I realised my alarm is not working erither. I would be grateful for any info
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    Check your keyhead, if the bcm does not recieve a signal from your keys then as far as I know the engine will not even try to turn over.
    Just as a simple test click the button on your keys and see if the central locking is working, if not then you could try replacing your battery in your keys and if that fails then you might be up for a bcm and keyhead to suit.
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    vr commodore
    Jul 2011
    south australia
    that is funny, my bcm lets my car turn over witout even a keyhead, i have a normal commodore key wit no electrics inside of it nad it runs fine
    Nov 2006
    Country Vic
    Quote Originally Posted by yoshi87 View Post
    I think I seen a post from you a while ago with a picture of you holding a key with no key head. To be honest that is the first vr that I have seen that has not needed the keyhead to start.
    If you happen to get a bit of spare time 1 day have a look at your memcal inside your ecm and see if it has been reprogramed and somebody has taken off the security. Or if you could get the code that is on top of the memcal.
    Also 1 question when you turn your key to the cranking position does it take a few seconds before the motor goes to turn over just for my own curiosity???
    Regards
    Mathew
    VS l67 statesman
    Dec 2008
    Possibly the neutral safety switch might be faulty if its an auto but check the above aswell
    vs commodore
    Oct 2009
    Tamworth NSW
    The VR gregorys workshop manual says that very early VR's didnt have the timed delay for the immobiliser bypass or override,these used the bypass key switch, located in the front passenger side door jamb near the door hinges.
    Also under the Body Control Module (BCM) section of the workshop manual,it says that theres two categories of BCM used on VR's depending on the model and equipment fitted.Utility,executive,acclaim,S, and GLI models are equipped with a low series BCM. Berlina,calais,statesman,VXI and newport are equipped with a high series BCM.
    Low series controls the following-
    central door locking (except utility),washer timer,security,courtesy lamp delay,auto lamps off,and if applicable,cruise control and power windows.
    High series-
    same as low series with the following extra functions-variable windscreen wiper delay,power aerial,speed sensitive power steering(calais,newport and statesman),instrument lamp dimmer,auto lamps off with delay,rear lamp failure warning,rear demister,and late model vehicles,the theft deterrent systrem.
    Early model VR's that had a bosch high series BCM have a seperate Theft Deterrent Module(TDM).
    The low series BCM is wired into the diagnosis connector for trouble shooting by an authorised dealer.The high series BCM has a seperate green coloured diagnosis connector which is strapped to the steering column.Early models are equipped with a key override for the security system,the later models have a timed delay period.
    Maybe these early models also didnt need the coded keyfob..
    The gregorys must class the mid BCM as part of the low series.
    vn ute
    Jul 2010
    adelaide
    Default dead Key head
    Quote Originally Posted by m62vpute View Post
    Thank you for your advise all that replied . Well the key head appears to be dead Ill try a new battery
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    Quote Originally Posted by b0mber View Post
    Did you get this working?
    VS V6 Auto Wagon Green
    VS V6 Auto Wagon White (LPG), going and no Rego - needs a good tidy up
  1. WH Statesman...wierd noise when accellerating off a left turn...ideas?
    By salty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 06:20 PM
  2. 5.0Ltr VR Statesman Air Cond/Fan WONT TURN OFF !!!
    By 5.0L StatesMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2008, 06:23 PM
  3. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  4. turn clock back. vr statesman
    By gold statesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 06:32 PM
  5. Problem with amp turn on/turn off
    By don80 in forum Car Audio
    Last Post: 05-06-2005, 08:06 PM
