Results 1 to 6 of 6
Thread: Fuel Pump Cradle
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Default Fuel Pump Cradle
    I had a dodgy fuel pump in my VR V8 Ute a few weeks ago and by chance I had a spare v6 fuel pump and cradle from a Calais just sitting there.
    The only noticeable difference on the sedan cradle was a return line on top which isn't used in the ute which I welded up and then just stuck the entire lot in to the tank and away she went.
    Now the issue I have is when I get to the last line above the E on my fuel gauge its starts to surge, and it never use to before. Its quite bad if you take a corner to fast it will just starve it of fuel and stall out.
    The only thing I can think of is the fuel sender on the cradle is out. Are the tanks in the Calais bigger then the VR Utes tank and im just simply running out of fuel before the dash says so?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Any chance you didn't install the swirl pot around the fuel pickup?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    not the bag, that bag at the end of the sender is another filter. the swirl pot is a black bowl which is mounted in the tank, there is a hose thats connected to the swirl pot which you have to connect to the sender. this stops the issue your having.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Ah ok... Well im off to pull the tank out and have a look see.. Cheers for the reply.
  1. VS commodore CAS or Fuel Pump? Fuel pump new BUT not priming on accessories
    By robert422 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2012, 08:14 AM
  2. Fuel sender, after changing fuel pump. Question that has not been answered.
    By seq4x4 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2011, 03:24 PM
  3. tip on removing diff cradle please ans where is the fuel pump
    By big steve q23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2011, 09:53 PM
  4. [NSW] Twin billet fuel pump holder for all BOSCH 040 044 pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 20-01-2011, 08:42 PM
  5. changing vt rear cradle to a vx series 2 cradle problems
    By TIN_MAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-07-2010, 10:25 PM
