Results 1 to 4 of 4
Thread: air temp sensor behind the MAF
    VS Wagon
    May 2009
    Wollongong, Australia
    Default air temp sensor behind the MAF
    Hi
    I have had a look but cant seem to find any information.
    Does anybody know if the air temp sensor can be behind the MAF sensor and if the car will still run fine?
    Thanks in advanced
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Yes it will be fine to position the IAT sensor after the MAF sensor.
    Not that there will be any great measureable difference in this instance, but technically, the further along the intake line the better as you will be reading a more accurate air temp that is being charged into the cylinder, rather than the temp in the air box. i.e. the further the air travels before reaching the cylinder, the more opportunity it has to heat up and therefore be a difference in the IAT measured temp and the actual temp going in with the inlet charge.
    Hope that makes sense, but in a nutshell yes it will be fine.
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive read before that the IAT (Intake Air Temp) sensor is located in the airbox so the computer knows the temperature of the air thats passing over the MAF.Thats why its located in the airbox before the MAF.In the MAP (Manifold Absolute Pressure) equipped vehicles,(eg-VR and earlier)that didnt use a MAF, the MAT (Manifold Air Temp) sensor was located up in the inlet manifold.
    VS Wagon
    May 2009
    Thanks heaps for the replies. I thought it would be ok but just wanted a second opionion
    Thanks guys
  1. Where is the water temp sensor located on 98 vt ???? (not coolant temp sensor)
    By 13thomo13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2011, 10:19 AM
  2. temp sensor
    By L-VrCalais in forum General
    Last Post: 26-11-2010, 10:17 PM
  3. oil temp sensor please help
    By boostinbt1 in forum General
    Last Post: 08-02-2010, 11:52 PM
  4. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  5. A4 Oil Temp Sensor
    By Leno in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-08-2007, 08:19 PM
