Results 1 to 3 of 3
Thread: Vr commodore series II wont go
    vt spac
    Oct 2010
    mnt druitt
    Default Vr commodore series II wont go
    Hey guys just did a gearbox service on my vr now it goes into gear but revs too 5000 and only moves with minimal power i need help urgently ive got a new job on monday and its not close so i need this car to work im bedazzeld i never heard of this please help it is urgent thanks in advance
    vs commodore
    Oct 2009
    Tamworth NSW
    When it was serviced,was the new trans filter and filter seal installed properly.Id be removing the pan again and checking that the filter hasnt dropped out of its locating hole..
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd agree with Brett - it's possible for the seal in the valve body to get dislodged when installing the filter or for it to be forgotten!!. Any leaks around the neck of the filter will make the oil pump suck air which then prevents the servos applying sufficient pressure against the cluches to stop them slipping....which is what your car is doing.
    I'd guess the oil level is correct?
  1. vs series 2 auto sedan wont start / no starter sound at all
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2010, 10:56 PM
  2. 94 Model VR Commodore V6 Executive Series 2 Wont Start
    By bubz187 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2010, 11:11 PM
  3. VN series 1 wont fire-up
    By v6lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2010, 11:46 AM
  4. VR series 2 wont start
    By im blonde? in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2009, 11:26 PM
  5. How to tell the difference between a Series 1 and Series 2 VX Commodore
    By ForceX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2005, 07:54 PM
