Results 1 to 5 of 5
Thread: When to replace brake rotors
    VS Equipe
    Jul 2011
    ACT
    Default When to replace brake rotors
    Hi All,
    New here but looking for some advice.
    My mechanic just advised me I need to replace front and rear pads and rotors since the rotors are now too worn to be machined. Since I now have the space I am planning to do the job myself.
    Firstly I am wondering how can I confirm I need to replace the rotors. I had a quick look and there are some slight and smooth grooves on the surface of the disc, and there is an overhang at the rim.
    Secondly can anyone recommend where to buy the spares. I would normally use a wreckers but not sure if that is great idea for rotors where they may have been sitting in the elements for a long time.
    cheers,
    Ben
    vs commodore
    Oct 2009
    Tamworth NSW
    Mate dont use second hand or machined discs.Brand new discs are so cheap these days theres no need to go second hand.Have a look on ebay for some new cheap discs to suit your car.Ive seen them on there before for $30 each brand new..
    Discs slowly wear down to a minimum thickness which for the VR/VS front discs is 20mm,and for the VR/VS rear discs is 8.5mm.
    Just had a quick look at ebay.Heres a couple that I found for an example,that are pretty cheap,but its definitely worth having a look through them all on ebay..
    ---http://www.ebay.com.au/itm/DISC-BRAK...item2eb0d91760---
    ---http://www.ebay.com.au/itm/DISC-BRAK...item2eb0d92f1b---
    You can also pick up cheap new discs up at places like supercheap auto etc..
    VS Equipe
    Jul 2011
    ACT
    Thanks for that, couldn't find the thicknesses. I'll go measure..
    Yeah, not too bad new, $66 for fronts from super cheap.
    vs commodore
    Oct 2009
    Tamworth NSW
    Just be sure to measure the disc where the pads run, and not just from the edge of the disc.You will need a suitable micrmeter to measure them properly..
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You could upgrade to slotted rotors and performance pads. I do a special curve slot and dimpled rotor for $180 plus $45 for pads.
    Visit my Facebook page
  1. VX: Replace rear rotors
    By kjparker in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2011, 09:49 AM
  2. [QLD] 290mm brake rotors Brake upgrade for VN/VP
    By mistergTRx in forum Parts And Other Items For Sale
    Last Post: 28-11-2010, 12:04 PM
  3. replace brake pads @ rotors
    By frogs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2009, 08:08 PM
  4. New brake rotors
    By myberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2008, 08:40 AM
  5. brake rotors
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2007, 01:56 PM
Tags for this Thread
