Results 1 to 7 of 7
Thread: v8 conversion
    vs berlina s2
    Apr 2011
    regents park
    Default v8 conversion
    hi all, i currently have a v6 vs berlina but also have a 185i 304 and auto sitting in my shed with the main engine wiring harness and computer and a v8 dash cluster, my question is whats involved with fitting it to my berlina and how much would it roughtly cost to pay someone to do the conversion?
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Should only take you and a mate a weekend if you have half an idea. You WILL need the K- Frame from the v8 to fit it. Other then that its a really easy swap. The fuel pump is fine from the v6 to run the v8 and the dash should all be the same. I did a swap into a Calais with a friend in about 8 hours but we only had an engine crane and a basic set of tools....
    But if it was to go to a shop then id say (at a guess) it could cost up to $1000
    vs berlina s2
    Apr 2011
    regents park
    yeah k frame i still need to get but should be able to get it pretty easy, what about steering racks? a mate attempted this conversion a while ago and gave up saying it was 2 hard, he said the steering rack is different so he got a v8 one and reckone the whole steering colum needs to be changed 2? he also have all the dash apart changing wires under there? is all that nessisary? ive only ever done v8 conversions on a kingswood and there easy as with no electronics or k-frames to be swaped
    VR Executive 3.8
    May 2011
    the steering rack should be the same and the wiring in the dash don't need to be touched, if you have any problems with the changeover though feel free to post more on here with what you have done and one of us can get back to you with an answer. I have actually done quite a fair few of these in last few years
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Yeah I just called my mate who I did the conversion with and he said the steering racks are the same and you will only need to replace the K Frame. He said he had an Auto Elec hook up his speedo and that was about it. The Steering column is the same also. Get in and do it mate, its pretty straight forward...
    jesse_lankey is offline what to put here?
    VS S3 Ute
    Jan 2010
    If I were you I'd just go for it, You should maybe consider a rebuild/refresh just to insure that it will run nicely when it's finished, you dont want to put the 304 in and have it blowing smoke or noisy lifters and then have to pull it out again... Just a suggestion
    vs berlina s2
    Apr 2011
    regents park
    thanks everyone for the advise sounds pretty simple just gotta talk the missus into walking to work so i can pull the car apart lol
  1. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
