Results 1 to 18 of 18
Thread: Need to replace water pump on vr 5L
    Vr senator
    Jul 2011
    Gold coast
    Default Need to replace water pump on vr 5L
    Hey guys Need some help need to replace water pump on my vr 5l is it easy and how to do it? Cheers
    V6 VR Acclaim
    Jun 2010
    Morton did an excellent write up about this procedure here. I just did mine and it's quite simple.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Vr senator
    Jul 2011
    Gold coast
    Aug 2004
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Its not hard, if you got any mechanical skill at all you will be fine just jumping in there to do it.
    Basicaly drain coolant, remove fan shroud and fan, remove hoses to pump, unbolt pump, clean gasket surface, install new pump.
    At the same time i usaly take the radiator out and give it a good flush to
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Vr senator
    Jul 2011
    Gold coast
    Yeah cool have radiator out having trouble getting fan off how foes it come off?
    Vr senator
    Jul 2011
    Gold coast
    Yeah cool have radiator out having trouble getting fan off how does it come off?
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    Should be bolts on the front or back of the centre of the clutch mechanism. Buy some loctite no.3 sealant when you refit the new pump and gasket, it's the best shit.
    Vr senator
    Jul 2011
    Gold coast
    Ok all can see on front is that metal twisted around tight and locked off no bolt only can see 4 on back for pump and 6 for the fan blades themselves
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    ??? Should have 4 bolts in the center of the aluminum clutch mechanism in the center of the blades(the bit with all the little cooling fins). Press down in the middle of the alternator belt to make it really tight, then crack the 4 bolts on the front. If you dont hold the belt down tight the fan will just spin and slip through the stationary belt.
    Reaper
    Vr senator
    Jul 2011
    Gold coast
    Vr senator
    Jul 2011
    Gold coast
    VrWagz1's Avatar
    May 2008
    wollongong
    Use some block soap (from the bathroom) and run it on the inside and out side edge of the belt. Just touch it lightly on the side as its running.....but whatch your fingers, cuffs, ect while you do it.
    If it stops, see if it comes back in a few days. If it does your belts prob dried out and you will need a replacement belt.
    Reaper
  15. #15
    Vr senator
    Jul 2011
    Gold coast
    Thanks mate will try that tomorrow hopefully works. Have noticed that is a bit loose too tho since I put it back on any way of tightening them?
  16. #16
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
  17. #17
    VrWagz1's Avatar
    May 2008
    wollongong
    If you think its sqeeling cause its slipping(the alt/water pump belt does need to be fairly tight) then stick a tyre leaver or pinch bar down between the block and the alternator and lever it out nice and tight.
    Reaper
  18. #18
    Vr senator
    Jul 2011
    Gold coast
    Ok will try in morning see how I go alt tightens up on that bar connected to the water pump yeah
  1. Water Temp/Water Pump?
    By Fred 96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2010, 01:58 PM
  2. How to Replace the water pump on a Gen 3
    By Mr. Incredible in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-06-2009, 08:36 PM
  3. about to replace my water pump
    By burnsy150 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2008, 03:07 PM
  4. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  5. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
