Results 1 to 9 of 9
Thread: Why can i hear the tappets under light acceleration in my V8,oil is NOT low
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    Default Why can i hear the tappets under light acceleration in my V8,oil is NOT low
    I noticed this small issue lately and cant help but wonder how long its being going on for since i usually cant hear it over the radio.
    The tappets tend to be noisy when starting but goes after a few seconds once the oil get up the top. Could i have a faulty oil pump?
    WTB:VR/S HSV 250km/h speedo cluster
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VS Equipe
    Jan 2011
    Adelaide, SA
    try a thicker oil
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    How long is a piece of string...?
    When was your last oil change?
    Is there enough oil in the engine?
    What sort of engine oil did you/they use last oil change?
    How many km's are on the engine?
    What sort of oil pressure do you have?
    shanhsv's Avatar
    May 2005
    Muswellbrook,NSW
    Oil change was about 7000k's ago
    Yes plenty of oil,i even topped it up to be sure
    Ive always used 20-50 oil and thats the same now
    Engine done 60,000k's since being put in the car (replaced with reco engine after 200,000ks)
    I have no idea of the sort of oil pressure i have?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Are you hearing the tappets or the injectors? My injectors are ridiculously loud and it does sound like lifters tapping.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    shanhsv's Avatar
    May 2005
    Muswellbrook,NSW
    I can hear the injectors,just but the tappets sound stands out a bit more then the injectors
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    If it's only when you start the car (and it's been services properly) the it will be a drain back issue probably try a better oil filter.
  1. Oil pressure light keeps going on and off every 5 mins or so on acceleration HELP!!!
    By eaquino in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2011, 04:55 PM
  2. VN- VR tappets
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2010, 05:00 PM
  3. Hissing sound during light/medium acceleration??
    By GILLO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2010, 11:48 PM
  4. rough acceleration under light load- IAC issue??
    By AWETZM in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2009, 12:12 PM
