Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By m62vpute
Thread: VR stato dash numbers fading
    holdenchik's Avatar
    holdenchik is offline www.myspace.com/justbec
    Purple VL calais
    Oct 2006
    maidstone, MelBurn.
    Default VR stato dash numbers fading
    The numbers on my dash are going away,
    mainly the KM's travelled, the ones on the right Speed Alert have completely gone.
    Does anyone know if this might be an electrical problem? It began when the battery went flat, or, could it be heat now i live in Cairns?
    they are slowly all going away.
    www.etstreet.com
    Drives a Maroon 95 VR Stato
    Prev car- OMIZVL- Purple VL calais mock
    VS Commodore
    Jul 2011
    holdenchik's Avatar
    Purple VL calais
    Oct 2006
    maidstone, MelBurn.
    the clock should read 250,012 but instead theres only 25 012, but even less then that.
    The LCD numbers fade, then stop appearing.
    www.etstreet.com
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by holdenchik View Post
    There are two main reasons for loss of LCD numbers. 1. White plastic fascia that holds the screens in place under pressure has failed. 2. The LCD has failed.
    Solution - best thing to do if purchase a cluster that you can run in diag mode to see all the segments light up on the trip computer (mode 3 in diag mode).
    and 3 Dangerous non ABS VN's
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    probobly bad earth or the lcd screen is just farkkked for the numbers to be really dull wouldnt it? no idea why the odo is reading more numbers than it should probobly a broken gear, easy to fix
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    holdenchik's Avatar
    Purple VL calais
    Oct 2006
    maidstone, MelBurn.
    88greenVN, usually im good with car talk, but can you please dumb that down for me?
    Jonnoo, the numbers just fade & fade, then stop appearing. I'l get a pic.
    www.etstreet.com
    88GreenVN's Avatar
    Jun 2006
    Sorry - I missed VL Calais. I'm not sure if the VL Calais ODO part is the same as the VN - VS ODO trip computer. If it is the 3 screens (VN to VS) are held in place against the trip computer PCB under a little pressure. The 4 globes over time cook the plastic (white fascia) and can snap the mount holes. The loss of pressure can let some segments fade on the LCD screens.
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    88greenvn I think you were right the first time as the post is titled VR stato dash numbers fading I think jonnoo threw you a curve ball about the odo with a broken gear on a digital dash
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    vs commodore
    Oct 2009
    Tamworth NSW
    I find that the LCD display in my speed alert stuffs up on very cold mornings,(0 degrees), and wont display all the LCD segments until the car has warmed up.
  1. VS Stato Dash into VS Calais
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2011, 02:27 AM
  2. Will vq stato dash cluster fit vg ute?
    By johnvncommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2010, 08:50 PM
  3. [SA] vr vs stato dash
    By hellbound in forum Parts And Other Items For Sale
    Last Post: 11-01-2010, 03:35 PM
  4. [VIC] VR/VS Stato dash
    By Troy5L in forum Parts And Other Items For Sale
    Last Post: 20-11-2009, 07:56 PM
  5. VN/VP/VR/VX dash part numbers?
    By calaiscruzer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2008, 09:55 PM
