Results 1 to 5 of 5
Thread: Cigarette lighter won't power devices (i.e gps, phone etc)
    Statesman VS S2
    Jul 2011
    Chadstone VIC
    Default Cigarette lighter won't power devices (i.e gps, phone etc)
    Hey guys,
    Ive got a statesman VS and im having a problem with my cigarette lighter. Basically, when i push it in it pops back out after a few seconds and heats up to light a ciggie, so there is definitely power coming to it. But when i plug in a device to it, such as a GPS or a mobile phone charger, it won't charge or power them at all! Any ideas?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Clean the contacts inside the lighter unit - they rust and also get dirty. Don't have the ignition on when you do this! Also check that the plug is being pushed fully into the fag lighter.
    Statesman VS S2
    Jul 2011
    Chadstone VIC
    Thanks for your help Hako, much appreciated. What should I clean it with and how should I go about doing it?
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    sandpaper.. would also try turning the plug when the device it in
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    VS Berlina/ KJ Verada
    Sep 2006
    Maybe try a replacement from the wreckers?
    Or wire in a new one from supercheap?
    In the 4 commodores I've had the lighter socket has always jacked me around...
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
  1. VZ No power to cigarette lighter socket
    By davevz in forum Electrical Wiring / Questions
    Last Post: 29-05-2012, 03:09 PM
  2. cigarette lighter/ power acc not working
    By surfdog in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-09-2010, 09:24 PM
  3. Ugh.. VT Cigarette lighter/Power Source..
    By bpottz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2009, 07:46 PM
  4. VX SS - No Power From Cigarette Lighter
    By nolim8ts in forum Electrical Wiring / Questions
    Last Post: 03-11-2008, 02:56 PM
  5. cigarette lighter to power neons
    By VSIIBerlinaL67 in forum Electrical Wiring / Questions
    Last Post: 23-12-2005, 07:58 AM
