Results 1 to 15 of 15
Thread: au thermos? need to know.
    vs ss manual
    Jun 2011
    camira
    Default au thermos? need to know.
    I have fitted au twin thermos to my vs ss and had an auto electrician wire it with a temp switch. Just need to know if and if so how big I would space the bolts which go into the water pump after the engine fan has bin removed. Think I read it's clutched and you have space the same distance as the thickness of the fan u removed but just want an opinion. Cheers
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I think i put 2 or 3 washers under mine.
    EDIT: Yeah 3 washers
    Reaper
    '94 Holden Calais VR V8
    Jan 2009
    Western Suburbs, Melb
    vs ss manual
    Jun 2011
    camira
    I did two and there probably not thick enough. But even two washers look dodgey
    VS
    Jul 2010
    Sunshine Coast, Queensland
    jesse_lankey is offline what to put here?
    VS S3 Ute
    Jan 2010
    VrWagz1's Avatar
    May 2008
    wollongong
    You could get shorter bolts, but is it seriously worth the effort. A quick trip to bunnings and a few 6cent washers later its all bolted up and ok.
    Reaper
    vs ss manual
    Jun 2011
    camira
    vs ss manual
    Jun 2011
    camira
    gilmer belt doesn't go on the water pump. may if I put an electric water pump I would be happy
    vs ss manual
    Jun 2011
    camira
    VrWagz1's Avatar
    May 2008
    wollongong
    ??Whats the issue with just throwing some washers under the pulley, go buy some and whack em in.
    Reaper
    vs ss manual
    Jun 2011
    camira
    2 or 3 it won't matter much at. how hard is it too fit gilmer belt drive with a/c and power steer on a vs. hard to change the a/c pulley or power steer. is it hard to space out properly wen fitting. hard to get bolts.
    VrWagz1's Avatar
    May 2008
    wollongong
    Reaper
    VS S3 Ute
    Jan 2010
    A gilmer belt drive would be the expensive option, however youre half way there with the thermo fans
  15. #15
    vs ss manual
    Jun 2011
    camira
    yeh washers r just short term solution til I get gilmer belt
  1. thermos/fan 4 vh-sle 308
    By jdoro in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-12-2007, 04:11 PM
  2. VT thermos vs AU thermos
    By ephect in forum V6 Development And Modification
    Last Post: 23-04-2007, 01:15 AM
  3. thermos
    By PEAKN6 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-01-2006, 11:09 PM
  4. Vs Ss Thermos
    By SS UTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2005, 05:19 PM
  5. Au thermos, ef-el thermos or davies craig On vp ss
    By jamo25 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2005, 02:18 PM
