Results 1 to 9 of 9
Thread: Oils leaks
    VS Berlina/ KJ Verada
    Sep 2006
    Default Oils leaks
    Been told recently I could be leaking oil from either/all of the following:
    rocker covers, valley cover and sump.
    I've changed rocker gaskets before, but how hard is it to change valley cover gaskets? Anyone able to show me some pics of where the valley gaskets go?? Nothing with 'valley' in the index of my workshop manual.
    Also the sump gasket, hard to do myself?
    Cheers guys.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    vr v6
    Aug 2009
    Valley cover gaskets are the inlet manifold gaskets.To change the sump gasket you would have to take the motor out ,or support the motor and drop the crossmember.Taking the motor out would be the best way, so you can replace the rear main seal and the torque convertor seal(if it is auto) at the same time.
    Sep 2006
    Quote Originally Posted by Guzzoline addict View Post
    Cheers, yeah I was going to do the rear mmain seal when i had my tranny rebuilt so i guess ill do the sump then too.
    95 VS Berlina
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Before you go replacing gaskets, degrease the engine and locate the leak otherwise you may be throwing money away. Rocker covers gaskets are prime items for leaks as is the rear main seal which can be impossible to seal.
    Sep 2006
    Quote Originally Posted by hako View Post
    Cheers Hako, been wanting to do this but I haven't got around to buying a longer hose to reach my driveway! When the nrma had a look their action plan was to replace all those seals as they couldnt't pinpoint where the leak was coming from. I can tell by looking that at the least its the rear main seal and rocker covers...
    95 VS Berlina
    Mar 2008
    if you need to replace your valley gasket there is a write up on here Vr inlet gasket replacement
    i have a max ellery's and it doesnt tell you much about replacing them
    i had a gregory's before was a great manual, till a mate left it in the car he sold
    Sep 2006
    [QUOTE=deanos70;1923465]if you need to replace your valley gasket there is a write up on here Vr inlet gasket replacement
    i had a gregory's before was a great manual, till a mate left it in the car he sold[/QU
    I have the ellerys too and you're right it doesn't offer much help there. Cheers for the link.
    95 VS Berlina
    Sep 2006
    Can loss of compression in an engine due to worn out gaskets cause any issues with the transmission?
    After changing all my inlet manifold gaskets the transmission doesn't seem to slip as badly as it did before but I do still suspect oil leaks from my sump and rear main seal, and I also believe my transmission is leaking fluid so would that also contribute to it slipping from 2-3?
    My brother had the transmission rebuilt while I was living overseas and as much as I believe he gave it a bit while he was driving it, he's not stupid enough to fork out for a new box then absolutely rape it.
    Would I be better off changing rear main seal, oil change and new seals etc before going for a reco'd transmission? Is there a seal between the back of the box and the driveshaft?
    95 VS Berlina
    Sep 2006
    E-nee-one?
    95 VS Berlina
  1. Oils aint oils
    By CANYONERO in forum LSx Development and Modification
    Last Post: 27-03-2008, 11:24 PM
  2. Oils Aint Oils
    By commisme in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-12-2006, 10:40 AM
  3. oils aint oils
    By carlyboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 06:59 PM
  4. Oils 'aint Oils - or are they ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2006, 08:51 AM
  5. oils aint oils ? ? ? ?
    By desruction in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-06-2005, 02:45 PM
