Results 1 to 5 of 5
Thread: Warning sounds after replacing globes in cluster
    94 VR Calais 3.8L V6
    Mar 2011
    Port Lincoln
    Default Warning sounds after replacing globes in cluster
    Hi, I've just recently changed my globes in the dash cluster in my VR Calais, one had blown behind the fuel gauge.
    Now I have a warning sound, similar to that of the Low fuel or the Handbrake on warning. I know it can't be the hand brake still on because it doesn't work, and I have a full tank of fuel.
    The sound is bearable, but annoying and I wish to fix is asap, can anyone help me out, I'm going nuts!!!
    vt
    Jul 2011
    qld
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    what is the tune you hear? the sound of the tune is different when your low on fuel to when the handbrake is on, how many notes in each group, how many times is it repeated?
    VS Berlina/ KJ Verada
    Sep 2006
    This happened to me the other day, its the handbrake on whilst moving tune. I pulled out everything I did and put it all back together again and it went away!? Guess I did something wrong the first time... maybe try that? Hope it works out bud.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    i have the same thing with my handbrake i have to hit it down hard or the light stays on and anoys me with the sound
  1. Replacing Fog Light Globes
    By SV666 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-04-2012, 07:47 AM
  2. replacing globes in ac/fan cluster on dash
    By jasonsvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2010, 07:01 PM
  3. replacing low beam globes
    By guyman in forum Electrical Wiring / Questions
    Last Post: 19-07-2009, 05:30 PM
  4. replacing globes
    By higgmont in forum General Discussion
    Last Post: 16-05-2009, 11:59 AM
  5. Need help changing green globes to blue globes in instrument cluster
    By GILLO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 10:40 PM
