Hey guys, anyone know how 19" 245/40 would go on my VS executive sII? just wonder about heights, camber wear etc, and also are 19"s legal on a VS?
how much would it cost to get them machined?
245/40-19 are not legal on a VS in Victoria as they are greater than 15mm difference from the largest tyre offered by the manufacturer for that model
205/65-15 @ 647mm dia.
245/40-19 @ 678mm dia.
On a VS, put 235/35R19 or 245/35R19. Nothing bigger than 35. It's illegal and also the tyres rub on the struts on the front and on the inside of the quarter pannels on the back (i've seen this, i've done this, you don't want this).
Originally Posted by Jasper44
Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
i had 245x40x19's on my vs statesman which back then was running -3.30" degrees camber rear and - 1.00 degree front and i had bare minimal clearance...not advised but will fit and bolt on...check your alignment specs but because if u have anymore then those specs it will rub the shit outta your car/tyre. I know run -0.30 front and - 2.00 with 245x40x19's and i have no issues and those bumps arent as nasty![]()
^^^ I doubt the OPs Exec will have IRS.
3.08 LSD, 1.9.1 High Ratio Rockers, MACE CAI, Spacers
so you guys are saying that the 245 doesnt matter, but i should reduce it from 40 to 35?
ps. What do 245/40 mean haha? i know their measurements but what meausrements :P
245/35/r19 is the only one you can do (legally) and maintain the minimum load rating (92 on my VS).
There are some 235/35/r19s with load ratings of 92 but they're very obscure..
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
thank you rx, pictures ALWAYS helpand cheers nath good explanation
ive been told ita only $25 per wheel to get them machined onto my car and will fit after that?
hi on my vr ss im running 245/35/19's on 8" rims on the front and 265/30/19's on 9.5" rims on the rear, the first set of rear rims we tried rubbed so we swaped for a different offset and have no clearance issues at all
around how much would a new set of tyres for them cost? (4 tyres)
