Results 1 to 3 of 3
Thread: mainfold gasket change
    elmaso's Avatar
    elmaso is offline PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    Default mainfold gasket change
    hey all i was planing on changing the valley seal, and i just have a few questions. do i have to disconnect the cruise control with the throttle body? or just leave that on?
    and the fuel pump fuse (depressurize fuel) is that the fuse with F/pump? (may be a stupid question, but just making sure lol.
    and if the plenum bolts are 3-6nm and the manifold bolts are 3-6 then 12-18
    cheers
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    You could leave the cruise cable connected, but to make your workspace in the engine bay less cluttered its easiest just to remove it. Personally, I remove the 3 10mm nuts that hold the cable bracket to the plenum and remove the throttle and cruise cable ends from the throttle body linkage, leaving the cables attached to the bracket only.
    Yes that's the correct fuse for the fuel pump.
    I don't have torque figures available atm sorry. Manifold torque sounds about right, but plenum bolts should be tighter than that. I'd certainly recommend investing $40 on a good (Gregory's) workshop manual that'll give you a user friendly step by step guide, also with all relevant torque specs etc.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Vr inlet gasket replacement
    My How to might help out to mate. its for a VR but similar steps
    I forgot to depressure the fuel when i was half way though, but just undone the clamp and was stuff all pressure anyway. Disconnect the battery !
  1. Vr wont start after gasket change
    By YILDI2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2011, 09:51 AM
  2. VR wont start after inlet manifold gasket change
    By muddyjunior in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2010, 07:39 PM
  3. Can i change a head gasket in a day?
    By peanut_finger in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-06-2009, 12:45 PM
  4. inlet manifold gasket, change
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-11-2008, 04:20 PM
  5. Ditz can't change a flange gasket
    By funkynoodle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2005, 07:53 PM
