Results 1 to 5 of 5
Thread: vr senator power window problem
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    Default vr senator power window problem
    ok. im having a problem with the drivers side front power window in my senator, its wierd because when i first jump in the car in the mornings to go to work i wind my window down and then it doesnt seem to wanna come back up, it doesnt matter how low i make it go down it just wont go up, and if i only wind it down a fraction it wont go up or down. but if i leave it for a hour or so it seems to work fine, anyone got any ideas?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    My guess is the contact in the switch is pretty much burnt out and concaved. Seen it happen with a few vn-vs switches with age and use. Id be trying a known working switch for the drivers side and see if that fixes it. You can also pull the switch apart to inspect the contacts. Prior to getting it sorted, i'd be avoiding using the drivers window, just incase it decides to stay down at the worst possible time.
    Dec 2005
    Burpengary
    VS Senator
    Oct 2009
    two-bit's Avatar
    two-bit is offline Hiding between the posts
    vs S pac series II
    Sep 2010
    Altona
    checked the relay? i had a similar issue with my climate control worked when it wanted to ended up being a faulty relay
  1. Power Window Problem
    By 3800SC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2011, 09:31 PM
  2. Another VN Power Window Problem.
    By stockies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2010, 04:35 PM
  3. power window problem
    By Kernal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 09:15 PM
  4. Power window problem
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2009, 10:31 AM
  5. help! power window problem!
    By skarekrow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2004, 06:22 PM
