Results 1 to 5 of 5
Thread: VS Thermo Fans
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Default VS Thermo Fans
    Hey guys,
    I was just wondering if anyone knows if VT/VX thermo fans will fit in a VS? Or are they too wide for a VS. Also, do you think that they would work alright or would they be too far away from the engine?
    Thanks.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    You can most likely make them fit. I got AU thermos in my 304. Not a great fit, but they fit and work.
    Reaper
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by VrWagz1 View Post
    Oh yeah sorry I forgot to add that mine is a V6 but in a couple of months its going to have the supercharged V6, thats why I was wondering if they would be too far away for the engine or not.
    If I ever get the chance, I might have to pull the thermo fans out of my WH Statesman and see if they fit. They should be the same as a normal commodore.
    VrWagz1's Avatar
    May 2008
    wollongong
    You should be ableto run whatever the VS super6 runs. Im not that sure that its anything special though, it may still run the stock setup for all i know. Depends on what u will be running really as to how much cooling you want. Maybe just seeing if you can get a thiker core in the stock size radiator might be a better less hassel and tidier way to do things.
    Reaper
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    You should be ableto run whatever the VS super6 runs. Im not that sure that its anything special though, it may still run the stock setup for all i know. Depends on what u will be running really as to how much cooling you want. Maybe just seeing if you can get a thinker core in the stock size radiator might be a better less hassel and tidier way to do things.
    Yeah your right. Well when I am ready to fit the engine, I will be replacing the radiator because I have never done anything with it since i've had it (except changing coolant). So I might see if I can get a thicker one. I thought that having the VT/VX style thermo fans would look nicer in the engine bay as well.
  1. thermo fans
    By v8commy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2009, 02:04 PM
  2. Thermo fans?
    By vkwalks39 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2009, 07:50 PM
  3. 304 AU or Ef thermo fans
    By v8_bomberdore in forum V8 Development and Modification
    Last Post: 03-08-2009, 07:08 AM
  4. WTB EL to AU Thermo Fans
    By Holmez in forum Swap / Wanted to Buy / Trade
    Last Post: 13-11-2008, 05:40 PM
  5. Thermo Fans
    By bigg_vin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-09-2006, 12:14 PM
